Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 53
Thread: I've soldered in my relay 4 different ways and it still won't work. Help please.
  1. #21
    Variable Bitrate vcbb5's Avatar
    Aug 2002
    Kansas
    my original idea was a timer, but it just wasn't easy to do. I should have pics in 10-15 mins (although it may be hard to tell what does what).
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
  2. #22
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by vcbb5
    You can pick up cube timers for about $25 at electronics store (not radioshack). But damn man, that's a lot of bucks.
    Tidder
    Try RevFE
  3. #23
    Aug 2002
    Kansas
    i don't want to post all the pics here, but here is a link:
    www.vcbb10.info/ShutdownController
    I'm not sure if my diagram is 100% correct, i got to rethink how i did all that crap
    My Mazda 3s
  4. #24
    Low Bitrate wonderworm's Avatar
    Jan 2004
    The second relay that shorts com pins 4 and 8, correct me if I'm wrong, but it's sole purpose is to provide a safer 5v to pin 8 as opposed to receiving 12v if pin 8 was wired to the IGN directly. Correct?
    Otherwise they are identical in purpose and function. Yes?
  5. #25
    Aug 2002
    Kansas
    UPDATED: I just updated the diagram to what (I think) is right now.
    Notes: The phone hookups just pass the:
    1. comp +
    2. comp -
    3. com pin 4
    4. com pin 5
    from the computer to the main hookup (the little plastic box). The box is connected to the:
    1. ignition +
    2. Car Ground for ig.
    3. inverter switch +
    4. inverter switch -
    As well as the phone cord to the comp.
    This setup puts virtually no power through relays (just enough to switch them), therefore a .5 or 1 amp relay will work just fine (both of which i used). I used: Relay 1 and Relay 2
    They are interchangeable and you can use both for both applications (my radio shack only had 1 1 amp and more .5 amp's)
    here is the updated diagram:
    My Mazda 3s
  6. #26
    Aug 2002
    Kansas
    I don't know the exact function of pins 4 and 8, but i would not connect a 12v lead to the com port, it will probably fry it. The little shutdown program is made specifically for the pins 4 and 8 to be shorted, not a 12v lead or another lead.
    another note: the shutdown program must be set to the inverse for this to work, not reguler.
    My Mazda 3s
  7. #27
    Jan 2004
    Thanks, this helps. That's also the same relay I am using. 3 questions:
    1. So you have the power coming from the molex connector of the PC and going to the inverter relay because that way if EITHER the IGN is on OR the PC is still on (still shutting down from software app), then the Inverter will remain on. Right?
    2. Looking back over my problem, what could be causing my inverter to go into overload mode when I plug in the pc to it. I have my .5amp relay wired just as yours. Maybe my ground is still not clean enough.
    3. What are the exact diodes you are using from radioshack? Zener Diodes of what specs?
    Thanks.
  8. #28
    Aug 2002
    Kansas
    1. Correct. Make sure to use diode so ig power doesn't go down comp line or vice versa
    2. I'm not positve, but try a smaller ac thing (to make sure pc isn't drawing too much power). Also try hooking the other end of the coil as the ignition to the same ground as the ignition (idk where you got the wire, but i got mine from radio harness, and used a ground on it). I'm not quite sure what wires you have hooked where on the relay though.
    that is exactly what i did for mine.
    3. I think i used http://www.radioshack.com/product.as...%5Fid=276-1101 but any small one should work.
    My Mazda 3s
  9. #29
    Aug 2002
    Kansas
    does that help?
    My Mazda 3s
  10. #30
    Aug 2002
    Kansas
    I would also suggest that you read up on relays here:
    http://www.the12volt.com/relays/relays.asp
    My Mazda 3s
