Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 53
Thread: I've soldered in my relay 4 different ways and it still won't work. Help please.
  1. #41
    Low Bitrate wonderworm's Avatar
    Jan 2004
    Thanks for the help. I'm going to skip the relay for now since it is taking too much of my time troubleshooting it. If the little relay still gives me a problem when I get back to it, then I will just get the big 30 amp relay and wire it inline with the main power. For now i'm just going to continue using the on/off switch of the inverter so I can get busy on other projects and wait and see if someone posts a magical solution to my little relay issue.
    If someone is a relay expert and has wired a small relay to only the inverter's switch, please double check my diagram and make sure I'm connecting it properly. Other than that, it's not that big a deal to flip the inverter switch manually for a short while so I can finish the rest of the project.
  2. #42
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Let me tell you what I used. I hooked up 2 30amp relays to my inverter positive from battery. One of them is switched by my ignition, the other switched by my computer. I found that with one relay, it wasn't enough juice passing thru, and my inverter would die if my subs hit a deep note. So I decided on 2 and haven't had a problem. I hope that will help you some.
    As far as your relay problem, why don't you get a bigger relay? It's always better to have too much then not enough.
    Tidder
    Try RevFE
  3. #43
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Is there a way from 0,5V to trigger an output of at least 5V and maximum of 25v??
  4. #44
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Base on the diagram, you are connecting the relay and the switch in serial. Try to wire it in parrallel (N.O to "I", and COM to "O") and leave the switch OFF to see how it works. If the inverter still beep for low voltage, turn the switch ON without turn off the relay so that 2 switches (switch and relay) work at the same time.
    I am wondering if the switch is there to just "switch" or it actually carry the load. If it actually carry the load, you are better off just get a big relay (30A or 40A) and wire it between the battery and the inverter.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #45
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by DjBac
    Anyone???
  6. #46
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Anyone???
    R U wording that right? Do you want it to trigger something else or pass through the .5v relay?
  7. #47
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Yes. Use an opamp configured as a comparator. The output will swing to the supply rails and can be used to switch other stuff.
  8. #48
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by Rob Withey
    Any link or abit more help?? Thanx!!
  9. #49
    Apr 2000
    Bedfordshire, UK
  10. #50
    Jun 2004
    GREECE/Athens
