Results 1 to 10 of 12
Thread: opus 150 watt PSU ?
    Toronto, On
    opus 150 watt PSU ?
    Where did it go ? I tried finding it and it wasn't there I only chould find a the shuttle pc one would the shuttle pc fit in a normal case and wats the diff between this and the other one that mp3car.com had ?
    Later
    http://members.cardomain.com/superv
    1997 Toyota Corolla
    CarPC Prep Specs:
    Its all here
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Maybe they're gearing up for the 220W....and have run out of the 150W.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by pip
    That would be cool. Hope the 220w version will not fully comply with the ATX spec so it would turn off the 5v when the car is off.
    Toronto, On
    Quote Originally Posted by 0l33l
    I'm hoping for that too i'll email mp3car tonite
    1997 Toyota Corolla
    CarPC Prep Specs:
    Its all here
    Constant Bitrate KaiTech's Avatar
    It will comply with ATX, but you will have a jumper that will turn standby off. Plus it'll have remote trigger output like the some 90W ones have.
    I'll spout simplistic opinions for hours on end.
    Ridicule anyone who disagrees with me,
    and generally foster divisiveness,
    cynicism and lower level of public dialog!
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by KaiTech
    Sweet! And the EPIA SP comes out about the same time Now if I would just have money and time to get a LCD display (I'm leaning towards a used Xenarc because I will have to remove it from its case to make it look stock (I don't feel like resoldering the connections on a Lilli), and I don't want it failing).
    so the 5v on the 150w is always on? is there a jumper on the 150w version to turn that off? Cause I don't realy like to have it like being always on...I guess putting a switch between the cable to the battery will fix that to...
    Aug 1999
    Washington D.C.
    Quote Originally Posted by ThaBoy
    The standby power is always on per the ATX spec in the 150 watt OPUS. Searching around here find some work arounds if you don't like that.
    Quote Originally Posted by Zip-Lock
    ok, thanks Zip...but I don't realy get why they do that...won't that drain your battery?
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    because the ATX specs were designed for a PC not a car PC?
    Signature: [==||========] 20% complete
  1. FS - OPUS 150 watt PSU
    By vash in forum Classified Archive
    Last Post: 07-31-2004, 04:00 AM
  2. OPUS 150 watt now in stock in the official mp3car store!
    By Zip-Lock in forum Power Supplies
    Last Post: 06-24-2004, 07:56 AM
  3. Opus 150 watt psu and Shuttle st62k
    By ryanreko in forum Power Supplies
    Last Post: 04-15-2004, 01:17 AM
  4. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 03:44 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
