Results 1 to 10 of 17
Thread: How to hook up the Opus to the battery ...
    Central NY
    I have been searching for this answer for a few days now, and haven't found any reliable information. I have the Opus90W, and want to install it in my car now, I assume I run a wire from the battery directly to the PS? What gauge wire do you recommend (going from the battery to the console in between teh 2 front seats, not trunk)? What kind of fuse should I get, and how to hook it up? How did you connect the wire from the battery to the Opus power supply, did you solder it or create a connector? How do you connect the wire to the huge battery terminals? Can I connect the Xenarc 7" TSV monitor to this PS or would it be too big of a load? Thanks guys!
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Is this covered by the dirctions in the OPUS box?
    Have you installed an amp in a car... it would be the same wire set up.
    TruckinMP3
    Read the FAQ!
    FLAC ppgt94's Avatar
    May 2001
    USA
    It is basically the exact same way you would install an amp. Get a amp installation kit rated for the correct wattage. Over-estimate to leave overhead (wattage) for possible upgrade or other things you might add in the future. The kit should include all the wires, fuses, and connectors you'll need.
    Do a search on google for "installing a amplifier" or something of the like.
    Central NY
    I have never installed an amp before, and no instructions were provided with my opus, it came in a ziplock bag, bought it from mp3car.com.
    May 2001
    USA
    Quote Originally Posted by electron
    Did you read my post? http://www.google.com/search?hl=en&i...g+an+amplifier
    Central NY
    I know I can google for this, but I posted here as there are many others have the exact same setup and could give me some tips that apply specifically to the opus PS. I will look at the installation kits in my local stores, thanks for the tip.
    Jun 2002
    Colorado
    Great, well at least you admit to being Lazy.
    TruckinMP3
    Read the FAQ!
    Central NY
    That was some great information you had to share! Googling on how to install an amp is much EASIER than posting a detailed message on a message board, and wait a few days for an answer. If you don't want to share any installation techniques or tips when it comes to hooking up the Opus, then why waste the board resources and my time? I didn't even realize that it was similar to installing an amp until someone told me in this thread.
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    I ran 14awg wire from my battery to my 90watt OPUS. It's at about the same location as yours. Unlike what some will say, my wire doesn't even get warm. 14awg copper wire at the length you need will carry 8amps just fine.
    Make sure you use a fuse with your wire near the battery. A 15amp fuse should be good.
    Don't run your ground to the battery. Connect the ground to a solid piece of metal nice and close to the OPUS.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Central NY
    Thanks, that's exactly the kind of information I am looking for. If I remove the plastic tray from my center console, I have access to the frame, I assume if I sand it well it would do the job when it comes to grounding it ? How did you physically hook up the wire to the battery terminals, or did you use an amp installation kit? Thanks!
  1. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  2. OPUS 150 low battery shut down
    By archimense in forum Power Supplies
    Last Post: 09-08-2004, 04:28 PM
  3. Help with Opus 150w hook up for newbiee...
    By jedi7001 in forum Power Supplies
    Last Post: 06-08-2004, 10:05 PM
  4. opus 150, how long will it run on battery
    By beaverpants in forum Power Supplies
    Last Post: 03-12-2004, 08:14 PM
  5. Wiring Opus directly to battery, please help!
    By touser in forum Power Supplies
    Last Post: 02-08-2004, 01:38 PM
