Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Will Opus 90W work with this setup?
    Newbie Jiroe's Avatar
    I'm running an Asus A7N8X with an AMD Athlon 2500, 2x 512MB PC2700, GeForce 4MX and a single 80GB HDD.
    My question is: is anyone else running a comparable setup with the Opus 90W PSU (from the mp3car.com store)? Is this too much system for the 90W? Have you had any experiences with the 90W that really turned you off with a particular setup? Is it worth it to wait for the 150W to be available? I want to get the Opus 150W, but I can't find it in stock anywhere and it looks like it'll be at least a month before the 220W is available, and I'd like to at least get the basic system in the car before winter. I can add to it later, when the 220W is out and available.
    Thanks.
    First CarPC
    Current Phase: Phase III - Configuring/Installing
    Current System Specs: Asus A7N8X w/ AMD Athlon 2500, 512MB PC2700, 80GB WD 7200RPM HDD, NVidia GeForce4 MX
    Current Total Cost: $527.45
    Droppin' this little nugget in a 98 Camry LE.
    Yup, the second place I went (after checking the mp3car store). It seems they have the 90W version in stock, but I'd hate to buy it to find out it won't sufficiently power my system. And through my ing, it seems that inverters pale in comparison to the Opus's. Plus, I like the integration with the ignition system.
    First CarPC
    Aug 1999
    Washington D.C.
    That's too much for the 90 watt. Go with the 150 watt.
    FLAC ppgt94's Avatar
    May 2001
    USA
    Quote Originally Posted by Zip-Lock
    Is it in stock? That's his only reason for not getting it.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Do you need the monster power on the vid card?
    It's cool but would a lower power and less heat solution work for what you want?
    TruckinMP3
    Read the FAQ!
    I don't absolutely need the current video card. The board doesn't have onboard video, so I'll need something. I can swap it out with a less demanding card (I think I have a dual-screen GeForce 2 somewhere).
    First CarPC
    Got an email. They'll be in Oct. 7th. Hopefully mp3car.com store will have them too, they're cheaper here.
    First CarPC
    Jun 2002
    Colorado
    Quote Originally Posted by Jiroe
    Your choice, It was just an idea.... I am using an old PCI card. I am only running WinAmp though so it is more than I need.
    TruckinMP3
    Read the FAQ!
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    The AMD 2500 is going to peek at around 68watts. The MX4 will be about 30 watts. Two sticks of DDR ram will cost you about 20 watts. You're already at 118watts. We haven't even talked about mother board power requirements, hard drives, and any USB devices that you are planning to hook up. I think it's safe to say that the 90watt OPUS is not going to cut it.
    If you absolutely can't wait, use a regular power supply and a 120volt power inverter.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Banned
    Feb 2004
    no way is the 90watt gona hold that much power. wait for the 220w opus
    -Nico
  1. Is opus 90w enough?
    By bbrother in forum Power Supplies
    Last Post: 09-13-2004, 12:30 PM
  2. Opus 90W power supply wire, 8 ga wire?
    By muldrick in forum Power Supplies
    Last Post: 08-27-2004, 11:27 PM
  3. 2699 case with opus 90w power supply question
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 02:32 PM
  4. Opus 90w Survives Crank!!!!!
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 12:03 PM
  5. Opus DC-DC 90W 150W Pricing Dimensions Info
    By Linus in forum Power Supplies
    Last Post: 10-15-2003, 04:29 PM
