Results 1 to 6 of 6
Thread: Powering up normal ATX PSU
    May 2004
    I need to install 2 lcd monitors and a portable dvd player in my wife's car and decided to hook them all up to a normal ATX PSU with molex connectors since they all work off 12v. I figured I could then plug the PSU into an inverter and hook the inverter into a switched 12v source in the car.
    When I tried the setup with the PSU plugged into an A/C outlet in the house, the PSU wouldn't power up. After trying a few PSU's and determining that they were all functional, I figured out that I coudn't get any PSU powered up without it being connected to a motherboard.
    My question is, how do you get a PSU to turn on without it being connected to a motherboard/computer?
    Thanks!
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Are you sure that's the way you want to go? it seems like a lot of work for no reason. if it's a portable DVD shouldn't it run off your car 12v system? Same for the monitors. What you might need is a regulator to get a constent 12v but if these are made for automobile use you probably don't even need that.
    theres 2 wires on the psu that you bridge to get it to power up w/o a mobo
    i remeber seeing a tutorial for running dual ATX powersupplies in a computer a while back.
    i dont know which wores though, sorry
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    http://www.dslreports.com/faq/9208
    Just jump pins 13 and 14, see the page I linked to.
    2005 Ford Focus ST
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Short pin 14 to ground (pin 13).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jan 2003
    Ruston, LA
    Do it all the time with a paperclip
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Mastero MK-4 ATX PSU with features.
    By Mastero in forum Power Supplies
    Last Post: 08-23-2006, 08:49 PM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. Opus ATX and ITX PSU - Difference?
    By phoTToniq in forum Power Supplies
    Last Post: 09-22-2003, 04:21 AM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  5. AT / FULL ATX PSU FOR SALE
    By Mastero in forum Classified Archive
    Last Post: 01-09-2002, 01:54 PM
