Page 10 of 10 FirstFirst 12345678910
Results 91 to 100 of 100
Thread: 3 months of fiddling around and NOTHING!!HELPP!!!
  1. #91
    FLAC Mastero's Avatar
    Aug 2001
    India
    Outdidya .... Hello,
    Brother whine can be a *****... read all six pages. lets see if i can help.!
    First dont connect the Laptop use your current system HU & CD and see if there is any whine ..... Specially when you press the car horn ..?
    Second Connect "ONLY" the laptop (NO HU NO CD NO SCREEN) and dont wire it to the external sound card and tell me if you have whine through your laptop internal speaker when you pluged in..? again use the horn to test.
    Cheers
    Mastero
  2. #92
    Newbie outdidya's Avatar
    Jul 2004
    NY
    yeah , i basically traced it down to the inverter being the problem and causing the whine. then again , it can also be that the wires are all tangled together considering it is a small car and there really is not other place to run wires except from the front thru the car to the passenger side.
    What i was thinking was moving the laptop to the front trunk, but then i would need to find a way to make the laptop start on power on. Does anyone know a way i can do this? i looked thru the bios but i guess its not an option on laptops although my computer does have it. Is it possible to update the bios so it can start on auto power on?
    Paymayne ,
    Could u possibly explain this to me ? im a lil lost
  3. #93
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    A one shot relay/timer would do it. Wire it up to your power button on your laptop. Or even the uhh.. ITPS thingy from here. Pretend it's a desktop. As far as the BIOS goes, I don't think you can tell it to power on when power is sent to it, because it's a laptop. Wouldn't be a feature worth implementing I think, having a battery and all.
    Tidder
    Try RevFE
  4. #94
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    the shielding of the VGA cable.. its conencted to the outer part of the pins. If you wrap some wire around it and solder it on there ground it i bet it will def help.. i did this and it amazed me how much less whine i had, as well as how dramatic the change of alternator noise into the screen dissappeared.. no more lines
    throw a moon
    heuvos vin chevos
  5. #95
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Pac thanks for the tip man, I'm currently getting lines, and i think that might be the solution, thanks!
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
  6. #96
    Aug 2004
    tx, USA
    Quote Originally Posted by Pudge
    yea maYne,,, like all else,, make sure you get a good ground,, i tried a few places before i found one that eliminated it
    throw a moon
    heuvos vin chevos
  7. #97
    Oct 2004
    Arrow Isolating from noise.
    Outdidya:
    Please post your complete setup.
    Your problem is on your Hi impedance signal generation/transmission (before or inside your amps).
    Try this:
    Take some signal source (CDplayer, walkman, fmradio), POWERED BY BATTERIES, not your car battery, and feed your amps, THRU YOUR ACTUAL SIGNAL CABLES, make stereo tests for each pair of amp inputs.
    Is there noise? is only on some channels? Just work with channels having noise.
    NO==> your problem is on your signal generation. Try other hardware. Dont have enough info to help you. Dont think this is your case.
    YES==>Try connecting the signal source directly to your amps.
    Is there noise? NO?==> your cables YES==> your amps.
    If the problem are your cables:
    Your signal cables are working as an antenna for the noise, and inducing it on your amp inputs.
    After checking/changing any loose connection.Try this:
    HEY CHECK FOR LOOSE CONNECTIONS.
    1.Not common ground between your amps inputs and output of signal gen device. This is: for 4 channels just run 4 wires (running just the signal), not 8 running the signals and respective grounds.
    Not worked?? Try this:
    2.Run twisted pairs for your signals cables: buy some cat5 utp cable (Ethernet networking cable, patch cable)from any store, you have 4 pairs, ready to run 4 signals RUN EACH SIGNAL WITH ITS RESPECTIVE GROUND.
    Not worked?? (are you near any radio/tv/telecom station?) Try this:
    3.Temporarily try running the signal on tv antenna coaxial cable. EXTREEEM SOLUTION, dont think you need to buy coaxial cable to run your signal but if the problem is inducing noise and the failed the tries before, this should correct it.
    If the problem are your amps:
    Maybe need repair or change if it is/are new. It shouldnt make noise just for the input. Unplug any input cable, set max volume, you should hear the noise. No? maybe your problem are your cables you forgot some loose connection.
    Hope this help men. Post more info. LOT OF INFO.
  8. #98
    Aug 2004
    tx, USA
    dear lord,,,,, thats good info that i myself use to troubleshoot as well and came up with my current fix.. but you went off with that post,, good job
    throw a moon
    heuvos vin chevos
  9. #99
    Aug 2004
    tx, USA
    i wonder if he ever figured it out,,
    i hate when people ask for help and many a peep give good insight,,
    then he either fixes it or trashes the problem and just leaves us hangin,
    these forums are my soaps,, fakk days of our lives
    throw a moon
    heuvos vin chevos
  10. #100
    Constant Bitrate naveedh's Avatar
    Oct 2004
    ok, i cant be bothered to read all six pages, as many have answered most questions lemme tell you, if you have removed the egg and hardwired lilli. whatever u usin, u fried that **** man.. Ciggarette lighter = dirty unregulated power. But if its a lill, then u will only have to replace the lcd screen inside and mayber the circutry for the lcd only , and not the touch controller, cuz thats powered through the usb.
