Page 5 of 10 FirstFirst 12345678910 LastLast
Results 41 to 50 of 100
Thread: 3 months of fiddling around and NOTHING!!HELPP!!!
  1. #41
    Nov 2003
    Olympia, WA
    You've probably tried this, but is your headunit grounded? Not the black wire that runs from the harness, but a separate wire that's attached to the HU and grounded. I had the same noise and bought a ground loop isolator but that killed my sound as far as lows and mids go. So last night I grounded my HU and tested it. The noise was gone except for when I turn my HU up to 36 (volume level) but I never have it up that loud. The loudest I go is 20 and even that is too loud. So ground your HU if you haven't already.
  2. #42
    Newbie outdidya's Avatar
    Jul 2004
    NY
    Quote Originally Posted by JC-S60
    Try the capacitor!
    whats that ?
    i jsut totally got rid of my hole ****, i was messing around with it today , and i was like **** it , unwired everything and put it in the trunk. Until i find a solution i dont think im gonna set it up.
    The sound isnt really that bad even , like my friends notice it but no body complains about it besides me, i think it just might be me thats buggin out cause i want this **** perfect i guess. whatever , im gonna keep trying ****.
  3. #43
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Ya know, I had a crazy whining noise coming from my screen once. I even had it grounded. I still was getting a whine and it was interfering with my touchscreen. Finally I grounded it in three different places on the circuit board. My prob went away. I was thinking, you should ground your laptop mobo in a few places. Like ground the screw holes on a serial port or something. Ground using a contact point right on the circuit board, maybe 2 opposite of each other. Also try grounding your lilliput after the egg as well.
    Tidder
    Try RevFE
  4. #44
    Jul 2004
    NY
    Quote Originally Posted by Tidder
    Ive heard some bad stuff from doing that. Screens frying and ****. my screen is really customized for my car so i dont wanna take a chance, but i will try grounding it at different spots thou, sounds like not a bad idea, thanks again.
  5. #45
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    Your CD changer has an audio input? Are you possitive that it's an input? Maybe I don't know what I'm talking about but CD changers usually only have audio out, not audio in. Maybe you are saying that you disconnected the cd changer and used the leads for your sound card instead?
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  6. #46
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    where in ny are you from outdidya? if you're anywhere on long island or near the bronx i could probably take a look
    rebuilding carpc... kinda..
  7. #47
    Jul 2004
    NY
    Quote Originally Posted by The Grinch
    Rigggggght, well basically the cd changer has an output to the headunit, so i just disconnected the audio plugs and pluged them in my soundcard. So when i turn on cd changer, then i get my music.
  8. #48
    Jun 2004
    Toronto, Canada
    I'm going to asume that the laptop has a working internal battery. What happened when you disconnected the power and ran directly off the internal battery?
  9. #49
    Jul 2004
    NY
    When i disconnect the power and run directly off the internal battery, but the buzzin is still there just a lil less when its not plugged in. Which i guess means that the buzzing is coming from the inverter being powered even thou its not plugged in. I am currently looking around for a new inverter to replace this one. Maybe i can find one with better quality or something. Its just my laptop is old and ****ty name brand( KDS) so there isnt much **** out for it. Ill just keep looking.
  10. #50
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    Quote Originally Posted by outdidya
    i did this a long time ago... worked awesome... all external sound gone,,,,,, until.... oh no
    been about 6 weeks now,, waiting on my new one to arrive,, but yes,, mine got fried.... i had the neg of my FM mod and the neg AFTER AND BEFORE the lilli "egg" grounded to the same spot... hey at least i found the last of my sound probs
    next time,, i will use my PSU 12v Rail
    throw a moon
    heuvos vin chevos
