Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 100
Thread: 3 months of fiddling around and NOTHING!!HELPP!!!
  1. #61
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by outdidya
    hmm , so im gonna try that one. So i just cut off a piece of the audio wires going to the computer, and ground them the same exact way i did for the laptop right? i never though of doing that but i guess since its not a power wire comin from an inverter or nothing that i can ground them.
    this fourm is really helpful, a lot of people coming to me with suggestions and it is helping me a whole lot to basically try and tone the buzzing down. It seems with every step i do, that i can actually get rid of it more and more, i dont think ill ever get rid of it , but i guess if i tone it down to a bare min then it wouldnt bother me no more. Thanks everyone
    Just the ground. No left or right audio wire, just the audio ground wire.
    Tidder
    Try RevFE
  2. #62
    Newbie outdidya's Avatar
    Jul 2004
    NY
    Quote Originally Posted by Tidder
    okay , now im confused. what audio ground wire? Also , how do i sheild the usb ports and wat not. You were saying something about a sheild wire to the usb or something?
  3. #63
    Sep 2003
    New Mexico, USA
    ok, audio usually has 3-4 wires. A left signal, left ground, right signal, and a right ground. Sometimes the grounds are combined into one. The grounds are what you need to ground to your car.
    Edit: The shield on your USB is just that, the shield. It's the metal part around the port.
    Tidder
    Try RevFE
  4. #64
    Newbie thasaint's Avatar
    Jul 2003
    new york
    have you thought of trying it with a friends laptop to see if you get the same results?
    the flesh does not determine what is within.
    carputer is in begining status
  5. #65
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    um...dont ground the audio to the car. they are completely seperate circuits. just dont do it, thats not your problem. it might be the audio cables though. just dont splice into them. unless somehow its a shielded audio cable and you want to groud that for whatever reason
    rebuilding carpc... kinda..
  6. #66
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    I have never heard of grounding audio like that. I agree with Fant - don't do it. Sounds like a headache, a waste of audio cables, and I don't believe it will change anything.
    Has anyone else actually grounded audio like this?
  7. #67
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by fantomas
    I Don't care what you guys say, this is where almost all of my noise was coming from. I grounded my audio ground, and voila, all my noise... gone.
    Tidder
    Try RevFE
  8. #68
    Sep 2003
    New Mexico, USA
    Read this thread:
    Engine whine
    scroll down to post #11
    And, if you don't know what the hell you're talking about, or haven't actually tried it yourself, then shut up. What if this is the solution? You guys and your "well uhh... I don't think it's a good idea, but I've never actually done it" will discourage so many people, when this has worked fine for me for years...
    C'mon now man, leave it to the guys that know this stuff... not the newbs...
    It's one thing to have an opinion, but it's totally something different to have an unresearched answer. Voice your opinion man, that's what forums are for. But don't slam my answers when I KNOW it works. It just doesn't work in all cases.
    Tidder
    Try RevFE
  9. #69
    Sep 2003
    New Mexico, USA
    I knew I'd find it, read this thread too:
    Inverter + hum + external sound card
    Hmm... what fixed 97% of his problem??
    Tidder
    Try RevFE
  10. #70
    Jul 2004
    NY
    anywayz, i tried grounding the audio wires, and they help , but that not much. What i also noticed, that when my audio wires were grounded and the computer is off, not pluged in or nothing, and stock hu is still on , i get the buzzing sound, but once i unground them, it goes away. Does that mean anything or jsut that the ground loop is created when the power is not on or something , dont no but im sure thats not my problem.
    About my inverter, i have one of those inverter adapters with the rectangle palstic box in the middle of the wire. Attempting to ground this piece, but how do i get about that? should i take apart the plastic box and find something metal to ground it to inside. Didnt wanna take apart the plastic piece at first but im willing to do it now.
    thanks again
