Originally Posted by
Zznakie
4-. I reaped off my transformer and this is what I found:
Primary Side (3 Pins)
Pin 2 => 26 turns CCW (watching from Top to Bottom) doubled => Pin 1
Secondary Side (6 Pins)
Pin 2 => 5 turns CCW (watching from Top to Bottom) tripled => Pin 1
Pin 5 => 4 turns CCW (watching from Top to Bottom) tripled => Pin 3
Pin 6 => 4 turns CCW (watching from Top to Bottom) tripled => Pin 4
Back to Primary Side
Pin 3 => 26 turns CCW (watching from Top to Bottom) doubled => Pin 2
This is what I did:
Primary Side: Followed Arby's tutorial, so I made 3 coils, each having 3 turns of 18 gauge wire doubled up.
Secondary Side: Got a little bit confused about the pins and the polarity, so I just got the 22 gauge wire and wound up everything just like it was but with the double of turns so now it is:
Pin 2 => 10 turns CCW (watching from Top to Bottom) tripled => Pin 1
Pin 5 => 8 turns CCW (watching from Top to Bottom) tripled => Pin 3
Pin 6 => 8 turns CCW (watching from Top to Bottom) tripled => Pin 4
Here I have a lot of questions: What kind of glue should I use to join back the two parts of the transformer's core? I thought of using loctite's crazy glue but since I may need to apart it again for rewinding it (if something is not OK) maybe this is not a good choice. Since I'm having some trouble finding some of the PWM circuit, I would like to know how can I test the transformer alone? Where should I connect the voltage and what result should I expect? Where shall I do the measurings?
