Use a cig. lighter addapter from radioshack or walmart,it will regulate the power to whatever you set it at.
Hello.
Does anyone know a good inexpensive DC-DC power supply I can use to power up a 12V monitor? Its maximum power drain is 3A, nomimal is around 1A. The power supply must be able to work from 11V to 15V.
Would I be able to use PW60a for this purpose? I'm worried about the input voltage range. I can make it constant-on so it supplies power I need to.
2-15" ILO lcd w/DVI
6800 gt Duel DVI out
p4 1.6ghz flex atx board
1gb 400 ram
120gb(2-60gb raid) sata hd
2-60gb hotswap
WIN2K Pro SP2
M.A.M.E. w/2,300 games
CARPuter info
You could try to just hook the screen directly to your car's power system.
I'm not sure what you are looking for tho....
something for your car? or something to run the screen in your home?
In terms of car - I just wired mine directly into my car's system (through an inline fuse of course).
I don't want to take a risk of frying $500+ 10.4" LCD, so I'd like to get something to provide stable 12V. I just ran to the radio shaft and got a so-called 12V adapter. That thing turned out to be only a bunch of wire with an in-line fuse. Doesn't do me any good.
Going to see what else is available at Walmart, etc...
Oh, well, I just said screw it and looked up a nice 9V-18V to 12V DC-DC power supply I put my eye on a few months ago, thinking it could be useful for just such application. It's going to cost me $60, but it'll get the job done right.
$60???? Damn! Go to Radioshack and get the generic one. I believe it's less than $20.Originally Posted by P4_2.66GHz
89 Mustang (Autox, road race, and cruiser)
93 Escort (Daily Driver)
84 Dolphin RV (Soon to be Carputer Heaven)
You would be better off with a CNX-P1260 (if you could ever get one)
Carputer currently 'ghettoed' into car!!!
EPIA MII-12000
Ampie Case with rigged extra USB
Hitachi 60GB
Holux GPS mouse with iGuidance 2.0
Lilliput 7" touchscreen
Netgear WG121 USB WiFi
Carnetix P1260
As usual, RadioShaft was of no help. If only they knew what they were selling.Originally Posted by DriverDan
There was no time to screw around.
I needed that thing Yesterday, hence the higher price, which included next day shipping. The unit I got worked perfectly in the environment I needed it to.
CNX-P1260 may have been used, but there was no need for a shut-down controller and I needed it ASAP.
P4 -
I'm looking for something similar... what was it exactly you ended up going with?
2004 Toyota 4Runner Sport 4WD
Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
I got a unit manufactured by MeanWell, model number SD-25A-12 (VDC IN: 9.2V ~ 18V; VDC Out: 12V/2.1A). It worked perfectly. On my testbench, it went as low as 7V before shutting down with a 7" test monitor connected to it.Originally Posted by roleary
