Results 1 to 7 of 7
Thread: Slightly Different ITPS Problem
    FRP
    FRP is offline
    Jul 2004
    UK
    I have read people's problems with the ITPS on here, but most seem to be not being able to get it to turn on. My problem is that it turns on, without the red (remote) cable being live.
    My set up is:
    +12v-----|--BL--|-White---|------|-Red----White---|-PW
    IGN +12v-|-OCK-|-Red-----|-ITPS-|-Black---Black---|-120-M
    GND------|-CON-|-Black---|-------|
    I have a block connector between the car wiring and the ITPS wiring (for easy removal of the PC) as the ITPS is inside the PC case.
    When I plug the connector in (IGN on or off) the pc starts booting. turning the IGN on or off does not send the command to start or shutdown the pc.
    I am gonna do some tests with the multimeter (maybe the red and white wires meet somewhere). Just thought I would check if anyone else has this problem or if I have missed anything why it might do this.
    FRP
    FRP is offline
    Jul 2004
    UK
    bump.
    any ideas anyone?
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I believe from your diagram you have the 12V constant connected to the RED wire on the ITPS. You would think that is correct but the ITPS's white wire is the one that goes to the 12V constant. The red goes to a switched connection.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    FRP
    FRP is offline
    Jul 2004
    UK
    Sorry for the crap diagram. I have the 12V constand to the white, the red is connected to the 12V only when the ignition is on.
    Oct 2003
    Poland, OH
    What is a block connector? And are you 100% the wire you have going to your switched is indeed a switched wire?
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by tbird2340
    And what happens if you leave that one disconnected?
    FRP
    FRP is offline
    Jul 2004
    UK
    Sorry for not posting about this sooner, stuck a meter across it and the remote wire, was in fact a permanent live
    Stuck in on accessories for now and working fine.
    Thanks for the help
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. ITPS Timing Problem
    By Entcee in forum Power Supplies
    Last Post: 10-26-2004, 06:30 PM
  3. ITPS Startup Shutdown Controller Not Working
    By EBJUSTIN in forum Power Supplies
    Last Post: 09-11-2004, 09:04 PM
  4. ITPS powering problem
    By mmstudios in forum Power Supplies
    Last Post: 06-01-2004, 08:09 AM
  5. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
