Have you considered an OPUS?Originally Posted by Arathranar
Supposedly available in the next 4-6 weeks. Sounds sweet:
Unfortunately for my I want to drive an AMD microATX motherboard so I still have to get the PW-120/200 & buy/build some kind of voltage regulator (leaning towards a 5.1Ah sealed lead acid battery + maybe the ITPS).The M1-ATX will be 80-90watts and it will work from 6-30 volts. It will also provide 9 timing schemes (available via user selectable jumpers).
Much better than a ITPS + PW-80 combined....
This is no P4/AMD material... The 12V rail can deliver only 3A. mini-ITX from VIA will certainly work.
We should have the board ready in ~4-6 weeks.
TruckinMP3
Read the FAQ!
Once the opus is in the ~$100 price range for a 120w/200w, I'll definitely get one. As of now, they're a bit too pricey.
any links or pictures?![]()
'96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
'00 Jeep Wrangler - planning stage
What can BROWN do for you?
Why on earth would I buy an Opus? The PW-120 or PW-200 are only $50 and are 200W and they're tiny. The opus loses on (I believe) every single possible point of comparson.
It's mentioned in the power faq on www.mini-box.com. Everything I posted above came from email conversations with a guy a mini-box when I asked about it.
Get a Mastero 4.1 . 200 Watt and integrated shutdown controller.
This guy knows what he's doing.
Mastero, You're the best.
Those look like they're DIY kits only, and for a guy like me with absolutely no soldering skills, 100 euros is pretty pricey if I have to pay someone to put it together for me on top of that.Originally Posted by Zznakie
And PW-120/200 + ITPS is probably cheaper and certainly a lot simpler.
I thought the same things as I had bought a PW120 some time back... of course I bought it before I had done any research... now I have learned a few things and have found plenty of info stating that the PW120 is rated higher but the 12V output of the power supply ISN'T regulated... the 5V stuff is but NOT the 12V... this means that your components can receive the full max of your charging system (up to 14.4V in most cases)... the ITPS will regulate the 12V up to like 60W... I'm gonna get the Opus once I get the cash together... not worth the chances with my stuff. Just my 2¢... Later!Originally Posted by Arathranar
Coach... aka Randy! (I often forget who I really am!) ;)
***Too many pieces and parts to list... maybe someday I'll show'm to ya!***
