Results 1 to 5 of 5
Thread: A tank circuit qn + Relay qn.
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    For a battery based tank circuit, if you use an SLA battery, what size are people using (how many Amp/hr?)
    Also, while ing for this, someone said "relays are bad" or something along those lines. (for use in isolating the tank battery). Anyone care to elaborate?
    Jul 2004
    Sure.
    I'm using an Optima D34/78 battery:
    http://www.optimabatteries.com/publi...eep_cycle.html
    with 55 A/hr. This is overkill, yes, but I like the low internal resistance (0.0028 ohms) and supposed long life of the Optima.
    Relays are bad because:
    http://www.surepower.com/pdf/ebr_int.pdf
    This is SurePower's corporate advertising to an extent, but it is also informative.
    I bought a Hellroaring BIC95300A:
    http://www.hellroaring.com/bic75300.htm
    as an isolator. It is nice because it has no 0.7V drop going into the batteries as conventional solutions do, thus wasting less power and creating less heat.
    I have installed all this and it works fine, but haven't gotten around to the computer yet, so I can't tell you if this setup is good for the long term.
    Variable Bitrate danon's Avatar
    Oct 2003
    Queensland, Australia
    Quote Originally Posted by nzKAOSnz
    anything is bad if not setup properly.
    ...come and join in:
    Multiple Battries
    danon
    [....99.9%]
    [HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
    [....99.8%]
    [SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
    [Working on] puttingBackEvrythg.
    Aug 2003
    55A/h??????? Hmmm yes..... overkill and over what i want to pay (optima)
    And what about the price of the isolator? Ouch.
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. Great working tank circuit with backup bat.
    By NightHunter in forum Power Supplies
    Last Post: 04-29-2004, 10:51 PM
  3. APC Battery backup used in tank circuit
    By antimatter in forum Power Supplies
    Last Post: 01-12-2004, 04:54 PM
  4. tank circuit
    By TiTUS in forum General Hardware Discussion
    Last Post: 09-07-2003, 06:05 PM
  5. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
