Alot of guys are using the OPUS power supplies. I am using an inverter with a relay hooked to the positive terminal on the inverter. This is probably the easiest was to do it. I haven't ever seen an inverter that this wouldn't work on.
As for the computer, a simple momentary switch wired to the motherboard wil get this done.
I'm using a laptop, so the wiring had to be directly soldered to the computer, and then wired to the cabin.
The computer does not like having power cut abruptly. If you are using a desktop, go with an OPUS. They seem to be the easiest to work with. If funds are short, you can use an inverter, but you must shut the computer down before cutting power. As for power up, I have two different switches to use before getting the computer on. There have been a few different methods of getting your computer on posted here. Just search and you shall find.
LinkBack URL
About LinkBacks
