Results 1 to 3 of 3
Thread: Inverter or regulator required?
    xga
    xga is offline
    Oct 2004
    Hi Guys,
    I'm a bit of noob to the whole CarPC thing and I'm currently looking at purchasing a Xenarc MP-SC1 CarPC and a Xenarc 700TSV LCD monitor. As both of these items operate on 12VDC, will I require any miscellaneous power items such as a power regulator or an auto start/shutdown device? Am I correct in thinking that I should be able to use both of these items without having to use an inverter?
    Any advice or recommendations would be greatly appreciated.
    Cheers,
    XGA.
    May 2004
    Since your battery gives out 12vdc, you won't need an inverter. I'm sure you'll need some sort of regulation though since the battery doesn't igve out even 12v.
    xga
    xga is offline
    Oct 2004
    Thanks Slitha. Can anyone recommend a suitable power regulation device?
  1. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 03:20 PM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  3. Help with inverter
    By Starkan in forum General Hardware Discussion
    Last Post: 07-10-2004, 07:43 PM
  4. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
