Results 1 to 5 of 5
Thread: Need schematic with itps
    Oct 2004
    Exclamation Need schematic with itps
    Hi im new on this web site. I have mini p4 computer works with 19v.Iam not using mini itx board. I am using 12v in and 19v dc out with itps board.but my computer does not turn on itps pulse becouse this motherboard on/off sw don't work like itx boards.so i tried to use a small relay on itps (on/off)conector.relay works but when ignition turn on itps gives signel to relay .relay turn on but always stay on until i turn off ignition.so my computer powers up but shut down in few second.please if some one help me to solve this problem.I need something like relay turn on and turn off with in second.Thanks
    Jun 2004
    Central California
    Hmm, that's kinda weird. Are you sure it's holding it in the on position? I have an ITPS also but mine does not hold it in on position.
    Try testing it with a multimeter (use continuity mode).
    FLAC mauri's Avatar
    Jan 2004
    Oct 2004
    Thanks for reply.may be I ask my question different way.I bought little pc from www.littlepc.com and that motherboard's power on/off sw does not work with ground.so if I use Itps with that motherboard nothing happen.so iam looking like any relay or something else can just close on/off button for half second.thanks
    Raw Wave
    Jun 2003
    You can use a DIP reed relay :
    http://www.maplin.co.uk/Module.aspx?...dID=3&doy=8m10
    This work off the TTL output.
    The ITPS grounds the motherboards switch so you will need to connect one side of the relay coil to the output of the PIC and the other to the +5V.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. ITPS-Auto Power Sequencer as Shotdown Controller
    By Nellor in forum Power Supplies
    Last Post: 03-16-2005, 12:24 PM
  3. ITPS Startup Shutdown Controller Not Working
    By EBJUSTIN in forum Power Supplies
    Last Post: 09-11-2004, 09:04 PM
  4. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  5. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
