Results 1 to 6 of 6
Thread: fuse accessories?
    Constant Bitrate studmonk3y's Avatar
    Feb 2004
    Honolulu, HI
    fuse accessories?
    I have a opus 150 watt and am planning on powering the lilliput and usb hub and whatever else off the opus. My question is do I need to fuse each of those (+) lines or do I not need to worry about it since the opus is regulated?
    Thanks for any help.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    i'd just fuse between the opus and the cat battery
    '98 Explorer Sport
    80% done
    Feb 2004
    Honolulu, HI
    Quote Originally Posted by hijinks21
    thanks for the quick reply
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Since you're fusing something, look at buying a circuit breaker instead. They cost a little more, but they're resettable and some have a lower voltage drop than a fuse.
    Jun 2004
    Hey,
    When I finally get around to putting in my carputer, I'm going to fuse every power line I run up to the dash, that way if one of them happens to short to ground somehow, only that device will stop working and it will be simple to troubleshoot because one fuse is blown and I know exactly what to test. I dont know if the Opus has fuses on its individual supply lines, because they assume the wires will be safely running inside a computer case with low chances of shorts, but running wires under the carpet and seats is a totally different story. Also, if you do happen to blow a fuse on the Opus board itself, arent they the solder-in microfuses that are hard to find and a pain to change, especially when you blow a few trying to fix the problem. It all depends on how cautious you want to be and how hard it is to rip apart your dash and run wires. Hope this helps.
    -Chris
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Even the cheapest PSUs usually have overdraw protection and will shut down in case of short without damage. Of course it doesn't hurt to fuse its output, but if you're hoping they'll trip instead of the PSU, it's pretty much a quick draw contest at that point - you'll want the fastest response fuses that you can get.
    Like hijinks said, I'd just fuse at the battery.
  1. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
  2. ITPS fuse rating
    By delussional77 in forum General Hardware Discussion
    Last Post: 05-29-2004, 12:34 PM
  3. quick fuse question....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-23-2004, 11:54 PM
  4. Which fuse type/holder do i really need?
    By Euclid in forum General Hardware Discussion
    Last Post: 11-04-2002, 04:00 AM
  5. fuse splitter, switches, noisy parts express 5" lcd
    By plasmadis in forum General Hardware Discussion
    Last Post: 07-21-2000, 11:06 AM
