Results 1 to 2 of 2
Thread: Powering a datalux screen from atx psu
    Question Powering a datalux screen from atx psu
    Hi I have a datalux 10.5 lcd touchscreen i just picked up off of ebay. I was wondering if you had any input on powering it. it takes a 12volt 3amp adaptor. What i had in mind was i got an idea of powering it off of one of my 4 pin psu cords (like the kind that goes to the hd). I wanted to pick that because it will not spike when i start the car and keep it running at a constant 12 volts. My question is to make the adaptor running from my computer to the screen is going to be about 10 feet. should i put a 5 amp fuse in there just in case and should i put anything with the power cords wrapping around it so it does not leave much interferance and what gauge wire should I use? I am new that this so please bare with me and thanks again for helping
    Feb 2003
    SE, PA
    I have mine hooked to my Datalux. Are you sure its 3amps, mine is only 1A
    I just bought a HD power extension cable, cut one of the ends off it, used yellow (12V) and black (gnd) that I extended the wires and used a DC power plug that I got from radio shack.
    Center pin is +
    You can use 14-16 gauge since its not much current. The fuse probably isnt necessary but certainly wouldnt hurt.
    G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
  1. 24VDC in ATX PSU
    By Julian in forum General Hardware Discussion
    Last Post: 03-18-2001, 06:26 AM
  2. Small DC/DC ATX PSU
    By gguy in forum General Hardware Discussion
    Last Post: 12-09-2000, 05:34 PM
  3. ATX DC/DC PSU
    By chapaudio in forum General Hardware Discussion
    Last Post: 08-24-2000, 10:41 AM
  4. ATX PSU
    By Bj in forum General Hardware Discussion
    Last Post: 08-20-2000, 09:57 AM
  5. KeyPower DC-DC ATX PSU
    By katnip in forum General Hardware Discussion
    Last Post: 08-08-2000, 02:16 PM
