Results 1 to 10 of 12
Thread: full ATX mobo and req. power
    Low Bitrate fishy's Avatar
    Oct 2004
    sydney
    Unhappy full ATX mobo and req. power
    Hi all,
    yep, im relatively new to posting, no, not new to reading or ing, BUT, i have spent many work hours (might aswell learn while someone else pays me!) trying to find out if the opus 150w would power a normal P3 667 full sized mobo with a mx440 vid card, 512mb ram, dvd drive and a tv tuner card?
    any ideas if that would work, i've tried about 15 different "wattage calculators" and all are as varied as the surrounding continents...
    if the opus is a no-go for the full sized mobo, would a 150w opus power supply substitue a 200w power supply for an asus "X" series (smaller mobo) with a P4 2.8ghz running similar peripherals?? (i could use a laptop HDD in the asus to keep power consumption down) both setups would ultimately need to run a USB GPS reciever too..
    plz help, im tearing my hair out with the amount of time researching power consumption figures, when i should be drawing up my blue-print
    FLAC -zip-'s Avatar
    Ontario/Canada
    I have much the same set up. Opus is going to release a 220W power supply in 30-60 days. They are also adding some new features, if you can I would hold off until then.
    I am.
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Oct 2004
    sydney
    thanks
    thanks Zip, i may just hold out, ohhh, but i want it all now, now now!! hahaha
    thanks Timmy, that is one of the many many wattage calcs i found on the net, it varies greatly between each site... so, which one to trust eh?
    Jun 2004
    I can't speak for the OPUS 150 watt pwersupply, but I have a media PC using a cheapo sparkle 200 watt PS, and I have no power issues with the following hardware:
    Chaintech Micro-ATX board
    AMD Athlon XP 2500+
    2x256 pc3200 RAM
    MSI TV@nywhere TV tuner
    D-Link 802.11g 54 mb wireless card
    80 gig 3.5 HD
    250 gig 3.5 HD
    Lite-on 4x DVD Burner
    CPU fan
    80mm pusher fan (with LEDs, not much more power used, but 60 extra HP like NAAAAAWS)
    2x 60mm puller fans
    Now it does use the on board sound/video/LAN so I don't have any of those add on cards. I also use various USB items with it, like a modem, and haven't ran into any power related issues either. It boots from the 80 gig drive, and the 250 gig drive is for capturing to, mp3s, encoding, and junk files.
    Aug 1999
    Washington D.C.
    Quote Originally Posted by -zip-
    Don't expect it before next year.
    FLAC -zip-'s Avatar
    Ontario/Canada
    sniff
    Super Moderator xBrady's Avatar
    USA
    Yes the Opus 150W will work just fine for your setup.
    When Opus says 30-60 days they actually mean 300-600 days.
    Installed.
    -GPSSecure- - GPS Tracking
    FLAC -zip-'s Avatar
    Ontario/Canada
    But Kaitech said 30-60 days
    ... but then again he said 30 days 60 days ago
    Zip-Lock any idea on cost yet? You can tell me, I swear I will keep it just between us two.
    Oct 2004
    sydney
    hahaha, true.
    i too sent an email to OPUS, and "Fernando" promptly replied to me that it will be available in 30-40 days, and gave me the closest supplier to me, which is in NZ (although im in Sydney, but anyway). It was great to get a prompt response, just wish the p/sups would be as prompt..
    Tried to contact this NZ supplier, but have had no response as yet, and the only way to contact them is via email
    well, if the opus 150w will cut it, i might just go with that, beats forking out for an inverter...
