depending on your laptops power supply and that products ability to produce a clean AC curve, yr laptop should work fine, although i would say try to find a laptop DC-DC converter, they are more efficient and will probably work better.
As for getting the laptop to turn on, there is a lot of information on this board, shutdown controllers that use the parallel port can be used to turn it off, as for turning it on, if the bios doesnt have a boot on AC power feature u may need to do some soldering to the power button connecting it to an ITPS or shutdown controller of yr choice (or relay with the ACC line).
HTH, no1knows.
LinkBack URL
About LinkBacks
