Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: DC-DC device ?
  1. #11
    Jun 2004
    Central California
    I think I finally found out what you meant with this alcas stuff. Is this it: http://schapenstal.homeip.net/alcas/...tional%20cards ?
    Although it looks like he uses the PS to power everything (MB & devices), I'm not very certain. Email him & ask about it.
    It seems to be a pretty good PS if it really does what he says it can do. Find postings of people that have built that PS. Email them and ask for opinions if necessary.
  2. #12
    Oct 2004
    hcker2000 > no I don't have a link
    edikp > sorry, I thought that ALCAS was better known sorry for my unclearness.
    Any idea on how I can get the negative lines ? (-5 and -12V )
    Or do I just have to switch the polarization ?
  3. #13
    Jun 2004
    Central California
    Quote Originally Posted by headtrip
    Well, the fact that I didn't know about it doesn't make ALCAS not popular. No apology accepted.
    I don't really understand your question. Negative lines? If you were asking about how would bring power to motherboard then get an ATX power extension cable (look @ attached image). Providing u hv a mobo with ATX power connection, of course.
  4. #14
    Oct 2004
    No
    An AT connector has pins with:
    +12 volt
    +5 volt
    -5 volt
    -12 volt
    my question was, how to get those negative voltages. Can I just reverse the polarization ?
  5. #15
    Jun 2004
    Central California
    How would you reverse it? The negative voltages need to be generated. Folks kinda talked about it here: Smallest way to get -5v
    Btw, are you just trying to save money on power supply by using an alternative? Rather than worrying for alternatives, buy an already built one. Mini-box.com has several that are relatively cheap (about $35). Or browse the For Sale section of this forum. Or eBay. Or..?
  6. #16
    Mar 2002
    Tucson
    No, you will have to use some type of converter to change the polarity. Most newer Motherboards do not require these additional voltages. You might be able to get by without them on older systems, if you do not need a mouse or pointing device. If you attempt to reverse the polarity on these lines, you will surely smoke your motherboard. The type of system you are describing takes a fair amount of power supply knowledge to construct. Unless you are fairly versed in switchmode power supplies, you might want to stick with an inverter and normal power supply.
    Just my opinions though
    Walt
    http://www.safossils.com/mp3car.html
  7. #17
    Jun 2004
    Central California
    Ah, there you go. Back to basic. Regular power supply & inverter. Thank you, waltsongs.
  8. #18
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Get an opus
  1. DC to DC converter
    By jdub421 in forum Power Supplies
    Last Post: 02-03-2004, 04:17 AM
  2. What are the ATX DC to DC power supply options?
    By Squeezer in forum Power Supplies
    Last Post: 07-08-2002, 05:25 PM
  3. Powering IDE HD with DC to DC
    By Destin in forum General Hardware Discussion
    Last Post: 12-19-2000, 09:07 AM
  4. atx dc dc
    By tre in forum General Hardware Discussion
    Last Post: 12-17-2000, 08:24 PM
  5. dc to dc ATX power supply
    By Kaizer Soze in forum General Hardware Discussion
    Last Post: 10-21-1999, 08:47 PM
