Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: cranking issue solved?
  1. #21
    Variable Bitrate Dracos's Avatar
    United Kingdom
    Oh yes, on my install, this is the exact route I will now be going - no variation. The only big thing I will be doing is to change to a lot better alternator to cope with the added strain of having to run the PC/ICE etc and charge TWO batteries.
  2. #22
    United Kingdom
    we all agreed this will work?
  3. #23
    Oct 2004
    Exclamation Dont agree.
    What do you call an isolator (whats inside, what does)?
    You don't need a device to separate current flowing to the batts, just putting the batts in parallel does the same. Are you planning to select wich batt are you charging?, if so, your car wil DRAIN its battery while you charge the other.
    Really, i think this is not good if it is just selecting batteries, or WON'T SOLVE THE CRANK PROBLEM, if it is separating current.
    For this option I prefer a relay, the best option. The diode is simpler to install, as no messing with car signals is required.
  4. #24
    A battery isolater does what it says - it isolates the batteries from each other. Think of it as 3 diodes - one from the alternater to a center point. And then one diode to each battery. That way the alternater can send current to both batteries but neither battery can drain the other.
  5. #25
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Interesting. since I am planning on putting a second battery in the car for other reasons, I might look into this. My battery has to be in my trunk anyway, so a second one wouldnt be that hard to install for me. how much so isolators cost?
    RevFE
    My Shop
  6. #26
    Quote Originally Posted by Mr Crown
    Why not. Many people are using this approach on this forum. I've read their threads. This is generally the exact approach they arrived at after long thread like this one and were successful.
  7. #27
    May 2004
    Where would one get such an isolator? any ratings/sizes specifically?
  8. #28
    Variable Bitrate HybridFox's Avatar
    Oct 2004
    Peterborough/Ontario/Canada
    im a newb but im pretty shure cranking is starting (please correct me if im wrong)
    but why not just have to batteries is parrelel with a heavy duty switch or disconnect hooked up in between the two batteries. so after you start you can just flick the switch and the batteries will connect charging both
  9. #29
    An isolator will do exactly that but automatically.
  10. #30
    Constant Bitrate dexy's Avatar
    Jul 2004
    NY
    Has anyone considered using a power capacitor. It will provide (stored power) for the little moment your car battery is loaded with the ignition crank.
  1. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 10:52 PM
  2. Cranking : Sign of weak battery?
    By masch in forum Power Supplies
    Last Post: 08-22-2004, 10:40 PM
  3. Replies: 6
    Last Post: 05-12-2004, 11:02 PM
  4. Stay alive while cranking
    By MerlinDaHapyPig in forum Power Supplies
    Last Post: 03-22-2004, 07:14 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 06:32 PM
