alternatively, you dont have to use a relay and splice into your starter solenoid cable - you could put an isolater switch somewhere on your dash. A DPST Switch that you flick before cranking, then flick back when the engine is started. The above diagram is just to take the manual bit out of it - but a switch could be put in its place should you want to.
LinkBack URL
About LinkBacks
the forums, but if i havent, i think i may have solved the cranking issue. looking at it now, it seems so so easy.
