Results 1 to 4 of 4
Thread: DC-AC Invertor power loss question
    May 2004
    I used to have a SIMA 300 watt DC to AC inverter with 2 3 prong AC outlets. (Used to as it got flooded with water and died) The thing I really liked is that the the DC leads from the ciggarette lighter had ring terminals on one side and the AC Outputs on the other. I taped right into the DC side to power my monitor.
    My question is by tapping into this DC voltage at the beginning of the invertor will it lower or make the current unstable for the AC devices?
    Im considering buying this invertor or type again because it was cheap and simple.
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    The current from a modified-sine wave inverter is pretty dirty/"unstable" as it is, hooking up the monitor won't have any effect on the inverter. Just make sure that the wires between the inverter/monitor and the cigarette plug can handle the total current draw of the inverter and monitor. Since you say it has ring terminals/posts, though, you can just use your own wire to connect it. 10ga should be okay.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    May 2004
    cool,
    Its the cheap temporary solution till down the road($35). Inverters are nice to have too. When you say dirty, is it a dangerous level? Does it spike like a car batery does during starting?
    May 2004
    Alameda, CA
    Nah, it still stays at 120VAC during crank, if it's capable of surviving a crank. The 175W inverter I used to use (not for comp, for other stuff) would shut down during crank. I don't know much about which inverters can survive a crank.
    I'm no electrician, but I can give you two basic examples of what "dirty" AC does:
    1) An electric clock will not keep proper time.
    2) I've plugged my tower computer into my inverter, and the PSU (460W) hums like a mudda fukka (it's a 1250W inverter). The computer still runs fine, though.
  1. Possible to turn a DC Toggle switch into AC???
    By Defiler in forum General Hardware Discussion
    Last Post: 07-05-2004, 09:29 PM
  2. AC, DC question
    By Navigator_82 in forum Power Supplies
    Last Post: 03-29-2004, 04:02 AM
  3. Question about DC DC PSU's
    By TMDJ in forum Power Supplies
    Last Post: 11-04-2002, 05:14 PM
  4. DC -> AC converter question
    By BRINET in forum Power Supplies
    Last Post: 03-25-2002, 03:21 PM
  5. Need help finding an AC to DC power adaptor
    By Squeezer in forum General Hardware Discussion
    Last Post: 12-29-2000, 01:27 PM
