Results 1 to 10 of 12
Thread: 3A 12v regulator?
    3A 12v regulator?
    If I can find plans or make plans for a 3A 12v regulator that will work from 9-18v input that would be great. The idea is to use a mini itx mother board + the pw-120-m. Sence the mini itx mobo dosnt use the 12v rail then I don't need to worie about that part. I just need a small 12v regulator so I can use full size hard drive and cd rom. I'm planing on puting the 12v regulator after the pw-120-m. So if any one has any plans that would be super great.
    ptk
    ptk is offline
    Singapore
    Quote Originally Posted by hcker2000
    see if you can find 3 pieces of the UM2702 (Universal Microelectronics)
    http://www.umec-web.net/
    each puts out about 1.25A. it retails for 18 SGD (about 10USD) each in singapore.
    that's the easiers way for me so far. I used it to power devices that are too far from the PSU to be run the power cable. I hacked the USB cable to run 12V through it (on both end) and run one of these babies to give me instant 12V & 5V. 5V sees too much drop when you run it through long USB cables.
    kao
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    Thanks for the info I'll keep those in mind. I'm hoping I can find a solution with a total cost of around $15 or so. Basicly just need enough to run a full size cd rom and hard drive.
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Natsemi has this nice IC.
    http://www.national.com/pf/LM/LM1084.html
    I've used them a couple of times, nice and easy and do up to 5A (a bit more if you heatsink them well). 1.3V drop out. A bit expensive to buy in small quantities, but they ship free samples to many countries.
    Denmark
    ... or combine 2 pcs. of 7812s (the S is for 2A) ... they cost next to nothing
    Ok will LM1084 be able to out put 12v if the input falls below 12v?
    No it won't. If people would read what others have posted rather than jumping at the chance to be a hero and offer what they think is great advice it would save a lot of trouble.
    What you want to do plenty of people are trying to work on. Regulating the 12V line in a car environment isn't easy and it won't be easy for you if you don't have more than basic knowledge of circuits.
    May 2002
    Australia
    Ah sorry i missed the 9-18V bit, thought he just wanted a 12V post regulator.
    Jun 2003
    Chicago
    use two TI PT5071 regulators with the outputs connected in parallel via schottkey diodes. I use four of these in parallel and it has worked great for almost two years.
    EBJUSTIN: dose it work when the car is runing and when the car is off? Also how many amp can it handle? and do you have a quick layout of the components?
  1. 12v regulator to suit morex 2677?
    By abitcrazy in forum Power Supplies
    Last Post: 08-21-2004, 11:33 PM
  2. 12v 1.5A in parallel produce 12v 3A
    By danon in forum Power Supplies
    Last Post: 01-22-2004, 11:36 AM
  3. Tutorial on how to install Regulator for 12v?
    By e36mp3 in forum Power Supplies
    Last Post: 07-05-2003, 08:14 AM
  4. 12v voltage regulator
    By masch in forum Power Supplies
    Last Post: 04-11-2003, 01:51 PM
  5. 12v 5a regulator for cheap?
    By Spongebob in forum Power Supplies
    Last Post: 02-19-2003, 08:12 AM
