Results 1 to 5 of 5
Thread: How to get 120VAC?
    Newbie bdqpdx2000's Avatar
    Cranbury NJ
    How to get 120VAC?
    I have an IBM NetVista desktop as my carputer (65W power supply). In order to not encounter any problems with crank power loss, I planned to have it hooked up to a small APC UPS. Now, the UPS won't switch off of its battery backup unless it's getting around 115VAC. I've tried a few power inverters rated at 150W+ 110VAC that only output between 83VAC and 95VAC (Manual says 90% max efficiency). Because of this, I either have to shutdown/hibernate the computer every time I shut off the car and only power on the carputer once I already have it started.
    So my question... how can I get around 110VAC in the car, or would an Opus power supply be appropriate for this application?
    Thanks,
    Dan
    Cranbury NJ
    42 views, no comments? Any help would be appreciated...
    Jun 2004
    Savannah, GA
    I have an opus and it works great and survives crank. I think a couple people have inverters that can survive crank but I dunno which one. Do a search on surviving crank is all I can tell you.
    Kefka_Killer.owns(you);
    Aug 2004
    Leawood, Kansas
    my inverter survives crank...my car falls to 10.8 volts on crank and my inverter shuts off at 10.5. (APC 350 watt...it does sound an annoying alarm I can hear from my trunk) I couldn't get a UPS to work either then I realized I was a dumbass and searched the forums and found several threads about UPS's not working off of an inverter...the wiring fault light goes on on the UPS.
    Compaq v6719 Athlon X2 tk-57
    Xenarc 7" Dash Install, iGuidance w/ iGPS 500
    HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
    94.3% of all percentages are made up
    Cranbury NJ
    gah... I was told by an engineer at work that a higher-rated inverter will be more likely to put out a more useful amount of voltage, so I guess I'll try that.
    By the way if you don't like the buzzer just take it out. I cracked open my APC UPS, tracked down the beeping sound (the buzzer looks nothing like a standard piezo buzzer) and desoldered it. The unit still works, and now without that annoying beep.
  1. Replies: 4
    Last Post: 04-22-2002, 07:50 PM
