Results 1 to 8 of 8
Thread: Wiring a laptop brick to Opus for at-home testing?
    I have an old power brick from my Dell Laptop that is starting to fray around the connector.
    Can someone give me some details regarding how to wire this to my opus-powered carpc, so that I can test and install at home?
    I think that my big question is how to figure out polarity.
    TIA
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    simple answer, use a multimeter.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Providing it gives ~12V and around 90/150W (7.5A/12.5A) depending on model, then it should work.
    As said, use a multimeter to check polarity, and also output voltage
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Ok. Thanks for the simple answer.
    Any chance you could provide a couple more sentences of step by step for someone who hasn't used a multimeter to any degree before?
    Thx
    Maximum Bitrate GingerPrince's Avatar
    Apr 2003
    Leeds, UK
    No.
    Opus really wants several amps (like up to 10). A Dell brick may supply 3 or so. You will not power a small aubergine with the brick via Opus I've tried using a 5 amp battery charger with an opus, which is more powerful than a Dellbrick, and that hasn't worked.
    Also, aren't Dell power supplies generally 19 volts? Or is it 15? If 15 it may be okay, but I'd still be very surprised if the current was sufficient.
    GingerPrince
    Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
    Carputer Install - http://www.stuffandting.com/carputer/
    CarBox Software -- http://www.stuffandting.com/carbox/
    Thanks. You're right, I think it is 3 or 3.5.
    Any thoughts on a quick/easy/cheap way to power it up at home for a little while for setup?
    Thx
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Use a desktop power supply and wire your opus to that. I use this method to test car audio equipment. (and to power my car fridge in my computer room)
    Tidder
    Try RevFE
    Apr 2003
    Leeds, UK
    Quote Originally Posted by Tidder
    That, or a 10amp car battery charger. They're a dirty 13.8volt supply, but that's exactly the conditions the the Opus is designed to work under!
    GingerPrince
  1. PC harddrive connected to laptop for home project
    By mrhic2 in forum General Hardware Discussion
    Last Post: 03-30-2006, 12:38 AM
  2. Laptop to be used for testing??
    By gman294_a in forum General Hardware Discussion
    Last Post: 06-03-2004, 11:26 PM
  3. Replies: 2
    Last Post: 05-17-2004, 02:19 AM
  4. how to run opus at home?
    By Nico3k in forum Power Supplies
    Last Post: 04-28-2004, 01:22 AM
  5. testing opus outside of car
    By aoLhaTer in forum Power Supplies
    Last Post: 01-10-2004, 04:18 AM
