Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: What inverter?
    What inverter?
    I shouldn't need more than 300watt. I know I have seen some people say there computers don't restart when starting the car. I would be very interested in hearing which inverters they have.
    Aug 2004
    Leawood, Kansas
    I'm using the APC 350 watt inverter that i got from compusa..I think retail it's about 80 bucks. It has terminals and survives crank (at least when my relay isn't controlling it)
    Compaq v6719 Athlon X2 tk-57
    Xenarc 7" Dash Install, iGuidance w/ iGPS 500
    HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
    94.3% of all percentages are made up
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I have a barely used Vector 750W here:FS: VECTOR MAXX 700 Power Inverter
    Had no problem with surviving crank.
    I just bought an Opus instead (smaller) to replace it.
    PM me if you're interested
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I use the radioshack 140watt special... $29. But it does NOT survive crank. Don't get a cheap one if you're planning on surviving...
    Tidder
    Try RevFE
    May 2004
    I've been using a Xantrex inverter for about six months now with no problems and it survives crank. It's only $30 shipped from Amazon.
    muldrick: thanks but a little to big and pricy for me right now.
    KimaX: how many watt psu are you useing with that inverter from amazon?
    May 2004
    Quote Originally Posted by hcker2000
    i have a 300watt PSU hooked up to the inverter
    KimaX: thanks for the info. Do you use full size components?
    May 2004
    yep...i have an epia M10000 with full size HD, DVD-RROM, 2 usb hubs with 6 connected devices and my xenarc monitor all powered by the PSU.
    Oct 2004
    I have a 800 watt rms / 1600 peak Coleman that survives crank (I'll never use an OPUS - not enough power for fast pcs). I do have 2 batteries tho... They are directly connected without any isolation (I have found isolation unnecessary).
    I generally don't bother running the PC with the car off though. You have to turn the key to make the accessory line hot to make the PC come on using the Power Controller I do (not anything mp3car sells, way better), might as well crank the car. Unless I'm going to be sitting there for a LONG time, but that only happens when I'm at home and then I just grab the extension cord...
  1. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 02:20 PM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 09:04 AM
  3. Help with inverter
    By Starkan in forum General Hardware Discussion
    Last Post: 07-10-2004, 06:43 PM
  4. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 03:05 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 04:53 AM
