Page 1 of 15 1234567891011 ... LastLast
Results 1 to 10 of 149
Thread: Opus wont power up, wtf?! Help please!
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    Hey everyone,
    I tried to but couldn't find anything so I guess I'll ask.
    I got my carputer installed, everything was working fine. Last night I was cruising around listening to mp3s and now this morning the computer wont power up at all. It did the same thing to me yesterday. Yesterday, i pulled it out, unplugged the harnesses and the fuse, plugged them back in and it worked. Today, nothing. I hooked up a multimeter to the power and ignition lines to ensure they worked and they did. I dont see the green status light flashing on the opus and it doesn't attempt to turn on. The power switch cable appears to be fine.
    Any ideas?
    Thanks,
    Chris
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
    Hrmmm.... So your saying that the Power and Ign wires that are going into the power supply have power but the Light isn't coming on?
    Out of curiosity what Opus is it? the 150 or the 90? Have you checked the battery? maybe the voltage is to low so the opus is going into OFF mode to save you from having to jump the car.
    Mar 2004
    Toronto, Canada
    yeah that's what i'm saying :S
    its the 90w opus. The battery is putting out 12-14 volts steadily, so I doubt the opis is saving me from having to jump the car am I missing someting?
    My XM FAQ
    Mar 2004
    Toronto, Canada
    well i just called opus and they basically just told me to remove the fuse fo ra few mins then put it back in.. tihs doesn't make any sense to me, do they expect me to do this daily or something if it works??
    My XM FAQ
    Mar 2004
    Toronto, Canada
    well i went and tried that and it worked. now the question is, am i going to have to do this daily?? what would cause this? any ideas?
    Thanks,
    Chris
    My XM FAQ
    Constant Bitrate KaiTech's Avatar
    possibly bad connection... on the fuse, cables or somewhere...
    I'll spout simplistic opinions for hours on end.
    Ridicule anyone who disagrees with me,
    and generally foster divisiveness,
    cynicism and lower level of public dialog!
    Mar 2004
    Toronto, Canada
    well after not happening for a week this happened again this morning. I tried removing the fuse for a bit like i did last time, nothing. Computer still wont boot up. Fuse is fine, connectoins are good. After I remove the fuse for a few mins, put it back in and plug in the wiring harness, i see the green led flash as I plug the harness in, but I dont get that standby flashing. Any ideas?
    Thanks,
    Chris
    My XM FAQ
    Quote Originally Posted by pyros
    Thanks,
    Chris
    So it only flashes once?
    It's a bit obvious, but is your ground good ?
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Sounds like a bad connection in the pigtail, sometimes the pins in the connector push out of place and don't make a perfect connection which shakes loose. Make sure the pins are fully pushed into place.
  1. 2699 case with opus 90w power supply question
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-04-2004, 01:32 PM
  2. OPUS plus power button
    By The Grinch in forum Power Supplies
    Last Post: 07-25-2004, 01:55 PM
  3. Opus 90w Shutdown Power off Porblems
    By antimatter in forum Power Supplies
    Last Post: 04-15-2004, 11:24 AM
  4. Opus 90w Power Action
    By EBoundEE in forum Power Supplies
    Last Post: 03-10-2004, 09:11 PM
  5. Mp3Car.com Store carrying OPUS Power Supplies
    By Zip-Lock in forum Classified Archive
    Last Post: 02-24-2004, 10:39 AM
