Results 1 to 6 of 6
Thread: Circuit for Power ON
    Aug 2004
    Leawood, Kansas
    Could anyone help me create a circuit that receives 12 volts, waits for 10 seconds, and then turns on a PC? Seems like it should be pretty easy with a timer, but I have no idea...I got a D in my digital circuits class
    Compaq v6719 Athlon X2 tk-57
    Xenarc 7" Dash Install, iGuidance w/ iGPS 500
    HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
    94.3% of all percentages are made up
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    This has been covered before (probably numerous times.) Here's the most recent thread.
    You can also check these out.
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I'm working on that same thing right now. Let me bump out a circuit, test it, and then I'll post a schematic here.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Aug 2004
    Leawood, Kansas
    I'm specifically looking for a circuit that momentarily pushes the power on button on the computer. The delay isn't as necessary. It just needs to be triggered by ignition to turn the computer on, hopefully a little bit after my amps. I know that there are some things that will do this, like some shutdown controllers.
    I had actually just read the thread that you linked, and I couldn't find anything specific on a momentary connection. I thought it would be good to have a thread that talked specifically about power on for us inverter users.
    moahdib's Avatar
    Jul 2000
    Read my post here:
    http://www.mp3car.com/vbulletin/show...d=1#post296106
    I just posted a solution using mastero's shutdown controller and adding some parts to it to do the job you want.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Low Bitrate nrls2000's Avatar
    Oct 2004
    Nebraska
    A simpler circuit that will do both power on and shutdown pulse. If you need a delay of 10 sec, then you will need to use a timer relay like the pac tr-7 or the dei 428t.
  1. Battery based tank circuit (tested)
    By Ricky327 in forum Power Supplies
    Last Post: 02-13-2008, 05:43 PM
  2. Help with on/off circuit for Mobo
    By powerslide in forum General Hardware Discussion
    Last Post: 08-16-2004, 02:48 AM
  3. Frying Circuit Board
    By Joe689 in forum General Hardware Discussion
    Last Post: 06-07-2004, 07:05 AM
  4. Poll: Group buy for a inexpensive startup/shutdown circuit
    By ScYThE in forum Classified Archive
    Last Post: 09-12-2003, 06:04 PM
  5. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 05:00 PM
