Results 1 to 7 of 7
Thread: quick question re: laptop power
    Oct 2004
    i've got a laptop power supply (cigarette converter) and it's output it 16v, max 4amps. my laptop takes 15v, 4amps. will the extra 1v do damage? or will i be safe to use it?
    if no, could i cut down the voltage with a resistor or something?
    cheers.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    It probably would work, but I wouldn't risk it, and it could shorten its life even if it worked fine at first. I believe you should be able to use a diode to get the desired voltage drop - but I'm no expert in these matters, so do some research first or wait till the experts around here chime in.
    Oct 2004
    thanks for the reply.
    i was fairly certain that it'd work, but as you said, it might do long term damage to some of the more sensitive parts...
    i'll check what the actual voltage is tomorrow when i can get to my multimeter.
    Oct 2004
    no-one else?
    Oct 2004
    bump, pretty please?
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    YOu would need a diode rated at least 10 amps, the diode should reduce the voltage by 0.7 volts and the 0.3 volts remaining will not do anything or else use a regular diode and a schottky diode to get about 1 volt. (the schottky is about 0.4 volts)
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Oct 2004
    thanks heaps!
    so i shouldn't risk the 1v?
    guessing i wire them up in series with the positive (red) wire?
    bare with me, i don't know too much.
  1. Power button extention on a laptop
    By oafdawg in forum General Hardware Discussion
    Last Post: 05-18-2004, 08:26 PM
  2. Laptop Power button
    By TA_ML320 in forum Newbie
    Last Post: 05-17-2004, 04:15 PM
  3. ITPS and Slim DVD Power question
    By no1knows in forum Power Supplies
    Last Post: 05-03-2004, 04:25 PM
  4. Just Cooler RF Remote power switch question
    By swzine in forum Power Supplies
    Last Post: 11-23-2003, 02:14 PM
  5. Quick Power question
    By BigStud3131 in forum General Hardware Discussion
    Last Post: 03-16-2000, 07:57 PM
