Results 1 to 9 of 9
Thread: I'm Confused about Opus & USB still staying powered
    Constant Bitrate Troy McClure's Avatar
    I received my Opus 150 last week and installed it this past weekend. I am extremely happy with it.
    Trying to stay ahead of the game I've read many posts about the USB remaining powered after shutdown. After installation and testing I noticed that the light on my USB Rikaline 6010 GPS Receiver remained on after shutdown. This really does not bother me, I know the drain is minimal and if it were to ever drain me completely then the beauty of owning a a car with a manual transmission will come into play.
    However, I don't know why but this morning I took a peek at the GPS before starting the truck and noticed that the light on the GPS was off. For the record, the truck started fine.
    Is it possible that the lights people are seeing on their USB hubs and my receiver are simply lighting due to residual power? If not, then anyone know why the light turned off on my GPS?
    me so confused.......
    Troy
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    perhaps if you gps dosent have a signal from a computer for a few hours it decideds to turn itself off because its not residual power
    Signature: [==||========] 20% complete
    I have an opus 150w and a USB GPS receiver, the light on the receiver goes oujt as soon as the PC powers down.
    Mar 2003
    Leave your gps plugged into a PC that is on, but don't run any applications that use it. If it turns off after a certain amount of time (with your machine on), you have your answer as Nic mentioned.
    Quote Originally Posted by chenko
    Hmm, good stuff. I'd be willing to wager you guys are correct. I'll have to try that and also see how long it takes for the light to go off. I do understand that power to the USB is an ATX specification so the GPS turning itself off when not in use makes alot sense.
    Like I said though, it's not a big deal to me in reference to my system, I'm just a curious person I guess.
    Troy
    Mar 2003
    If it stayed on all the time, It would keep your position locked for you not so bad I guess
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    wooooo wooooooo, and i dont even have one :P
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    its not "residual power"
    the opus 150w does supply standy 5v voltage
    i had my ops connected to an epia m10000 and it sucked 250mA and drained my battery once after not using the car for a few days
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    I believe this is pretty much the problem with the Epia boards (M10000)
    I didn't have this issue with my shuttle FV25. But now I DO have the M10000 and have to do the "mod".
    BossTone74
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. Wiring two OPUS to one computer system
    By lookinco in forum Power Supplies
    Last Post: 09-07-2004, 11:23 AM
  3. New USB powered 20/40 GB hard drive
    By random0000 in forum General Hardware Discussion
    Last Post: 08-27-2004, 11:49 AM
  4. USB 2.0 PCMCIA Card
    By Rith in forum Newbie
    Last Post: 06-13-2004, 11:55 AM
  5. Replies: 3
    Last Post: 05-28-2003, 09:45 AM
