Tap into the On/Off switch of the inverter by soldering a wire to each contact (take the inverter apart and access the back of the switch, it's usually a rocker type switch). Then use either your remote turn-on or another ignition-on wire to power a relay that would basically flick the switch on and off for you.
LinkBack URL
About LinkBacks
