Results 1 to 3 of 3
Thread: Automotive electrical noise filter (not ground loop isolator)
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I saw this at Radio shack and I was wondering if anyone had any experience with one.
    First question, does it work? and what kind of problems would it solve?
    Second, I have a laptop, and I believe that a lot of the noise in my system is coming from the power supply. If I got this, and put it above the power supply, I could send the filtered power to all my 12V components (screen, modulator, V1, computer power supply). But, if it is the case that the majority of the noise is coming from the power supply, it might make sense to put it between the supply and the computer. The power supply puts out 15VDC, and the filter is rated to 16VDC max, so it should be okay, right?
    Some more newbie questions:
    How do I determine what gauge wire to use for power and ground.
    Should you always use stranded wire?
    How should I make connections? solder then wrap in electrical tap?
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    I have one put between the power and the FM modulator and it really made the difference because the inverter I have kept making the stupuid buzzing noise. Now I just need one of those to put between the inverter and my laptop and my system will be quieter than your stock CD player Seriously though, they help. I suggest first trying to put it between the modulator and power, and if that doesn't help try the computer power.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by zPilott
    One good filter for the noise disturb eliminates its the component name Murata BNX002 10A support ideal for the power supply in the automotive use Carputer,eliminate 95% of elettrical noise ( filter the EMI-RFI noise)
    Its disponible for www.distrelec.it
    Mauri
  1. Ground Loop Isolator
    By Matthew230 in forum Car Audio
    Last Post: 10-28-2004, 03:11 PM
  2. Learn and fix ground loop noise
    By 14.4vTech in forum Car Audio
    Last Post: 07-03-2004, 09:55 PM
  3. FS: Radio Shack Ground Loop Isolator!
    By mwinkler in forum Classified Archive
    Last Post: 04-11-2001, 11:38 PM
  4. ground loop isolator help
    By digital chaos in forum General Hardware Discussion
    Last Post: 03-11-2001, 02:38 AM
  5. Where does ground loop isolator install?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 09-14-2000, 09:10 AM
