Results 1 to 8 of 8
Thread: Wiring Power Switch With Inverter
    Newbie Jiroe's Avatar
    I tried the Opus and couldn't get it to work after 3 days (but I think it's because I've got a PC that is drawing too much power for it to keep up). So I bought an inverter and it worked right out of the box. My next problem is: how do I wire the power switch for the PC to the front console? It's more of an aesthetic question than technical. I know HOW to do it, I was just wondering if anyone else is in the same boat and if so, how did you wire your power switch up? I'm just looking for creative ideas / potential problems to keep an eye out for.
    First CarPC
    Current Phase: Phase III - Configuring/Installing
    Current System Specs: Asus A7N8X w/ AMD Athlon 2500, 512MB PC2700, 80GB WD 7200RPM HDD, NVidia GeForce4 MX
    Current Total Cost: $527.45
    Droppin' this little nugget in a 98 Camry LE.
    Oct 2004
    Forget doing it manually, just use a separate power controller that sequences power on the inverter, amps, and PC. You can find one on ebay by searching for carputer.
    ColdPhreze
    14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
    200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
    2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    rebuilding carpc... kinda..
    Thanks for the quick replies. Basically, I'm just looking to see if anyone else has done this and how they did it.
    First CarPC
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    2 wires. one momentary switch
    Splice the two wires that plug into your power board from your power switch. Run them to a momentary switch. Bingo.
    Jun 2000
    NYC
    do a search here..i had the same quest..search - wiring inverter
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Basically you want 2 different switches. One for the Inverter and the otehr for the mobo power switch.
    - The mobo is easy. 2 wire (speaker wire work well) and a momentary switch (NO).
    - The inverter is a little harder. You can either control it by a switch directly or thru relay. If you want to switch the power wire (battery), then you must use relay as there are not that many small switch that can handle the load. Or you can just extended the inverter's ON/OFF switch. Inverter wiring has been cover a lot, just
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    Dont just put a switch in. Run a relay inbetween with a fuse. That is the safest way to do it.
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 10:44 PM
  2. Remote PC Power Switch
    By Terran in forum General Hardware Discussion
    Last Post: 01-06-2005, 09:13 PM
  3. Voltage going through inverter switch?
    By CoCa in forum General Hardware Discussion
    Last Post: 03-29-2004, 10:57 PM
  4. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 05:59 PM
  5. can this switch handle my inverter???
    By DJ in forum General Hardware Discussion
    Last Post: 07-25-2000, 08:46 AM
