Results 1 to 7 of 7
Thread: Strange Opus 90W problem
    Jun 2004
    Upstate New York
    Angry Strange Opus 90W problem
    Posted this in the general discussion section a while back but I think I've narrowed it down to the Opus. When I shut off the truck the PC shuts down normally, come back to the truck 15 minutes later everything turns on (HDD spins up, CPU fan spins up) but no BIOS beep and no VGA on Lilliput. Now here's the strange part, if I leave the system off for an extended period of time (while at work or overnight) it'll boot up totally normal. What leads me to believe it's the Opus is that today out of sheer exasperation with the damned thing I pulled the fuse on the Opus for a minute, put it back in, turned the key and all was good. The only thing the Opus is powering is my Epia V8000 motherboard and the Hitachi Deskstar HDD so I think 90W should be more than enough power for the system. I've been through every BIOS setting, loaded fail safe defaults, checked all the Windows Power settings and I'm still at a loss for an explanation. Anyone have any ideas what the problem might be or what might be done to solve the problem?
    Oct 2004
    Heat? It may be that the OPUS is on the way out and that even heat within normal operating limits is affecting output so that the PC will not fully boot.
    Does it happen if you use a standard power supply? Does it happen with the OPUS on another motherboard?
    ColdPhreze
    14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
    200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
    2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
    Jun 2004
    Upstate New York
    Haven't tried it with another motherboard yet, I never had the problem when I was using an inverter in my old truck so I imagine if I took a standard P/S out it would work fine. As far as heat goes, if I go out and turn it all on and shut it right back down again it'll do the same thing. No time for any heat to build up in the console by doing that, so I don't think heat is an issue. I'm going to go try a standard PSU now I guess to make sure that it's the Opus, if it is I guess I'll have to send it back since the install is only a little over a month old. Here's my theory on the whole thing please correct me if it's not possible. Seems to me that for some reason the Opus is still supplying some sort of power to the motherboard even though no jumpers are installed and it should be shutting down immediately. I'm not using standby but maybe it's still supplying standby power? Actually I was hoping it would end up being the Motherboard so I could replace the V8000 with an MII 12000.
    Had the same problem, open up the case and unplug the ATX power supply from the motherboard and then plug it back in, should be fine after that. When i plug it in at home everything works perfect, i plug the Opus it does not boot up, i unplug the atx and plug it back in everything works perfect. Hope this will be your solution
    Jun 2004
    Upstate New York
    Ok, works fine with a standard PSU so that rules out the motherboard. Disconnecting the ATX connector on the motherboard doesn't help unfortunately, neither does disconnecting the 3 pin power connector on the Opus. Pulling the fuse seems to be the only thing that makes it boot. Is there some setting that I've missed? I've been over and over the Opus manual 3 times soon to be 4. Opus works fine otherwise but I'd really like to fix this before it makes me insane.
    Jun 2004
    Upstate New York
    Update
    OK in my 4th trip through the Opus manual I came across this:
    "7. Connect the 2-pin cable (polarized side) to J5- (Power-switch) of DC-DC power supply. Connect the other end to the motherboard 2 pin ITX power switch/soft power switch pins on the F_Panel header. Important: proper polarity is required to function accurately. The green wire side of the 2-pin connector must be connected to the +ve side and white wire side must be connected to the – ve side of pins. VIA, EPIA-M ITX motherboard: F-Panel header Pin 6 is +ve (green wire side) and pin 8 is –ve (white wire side). Refer to motherboard user guide. Intel D815EEA2 motherboard: Front panel header Pin 6 is +ve (green wire side) and pin 8 is –ve (white wire side)."
    My V8000 manual doesn't say which pin on the header is which. Does anyone know if: if they were reversed would this cause my problem? I went to Opus's web site to contact tech support on this issue to see what they recommend. If they don't get back to me today I may just try it and see what happens. My line of thinking is that even if I disconnect that connector from the Opus and short the wires I still have the same problem so it's probably not going to fix the problem. I appreciate all the help so far.
    Jun 2004
    Upstate New York
    Update II
    Opus's response to my tech support request:
    If it boots up sometimes it means you placed the power-on connector in the
    correct direction.
    The Epia-V8000 motherboard has a compatibility issue with our power
    supplies.
    Some power supplies work and others don't, it's all based on a difference
    between the startup time of the 3.3V, 5V and 12V rails. Unfortunately Via
    does not wish to cooperate with us and try to resolve this issue, which
    could be done by a BIOS update.
    If you would send us the motherboard with the power supply we can make them
    work together for you, it will require some hardware changes in the power
    supply.
    We apologize for the inconvenience.
    Rafal Krawczyk
    Opus Solutions Inc.
    26941 Cabot Rd. S#120
    Laguna Hills, CA 92653
    Tel: (949)305-4200 Ext.225
    rafal@opussolutions.com
  1. Opus 90W w/ hardwired USB devices
    By beckkl in forum Power Supplies
    Last Post: 10-13-2004, 06:20 PM
  2. Will Opus 90W work with this setup?
    By Jiroe in forum Power Supplies
    Last Post: 10-02-2004, 08:07 AM
  3. Is opus 90w enough?
    By bbrother in forum Power Supplies
    Last Post: 09-13-2004, 12:30 PM
  4. Opus 90W power supply wire, 8 ga wire?
    By muldrick in forum Power Supplies
    Last Post: 08-27-2004, 11:27 PM
  5. wierd power problem (opus or m10000 prob)
    By ob1 in forum Power Supplies
    Last Post: 03-31-2004, 02:32 PM
