Results 1 to 4 of 4
Thread: Power Inverters (Pure Sine?)
    Oct 2004
    I have a MIPI pc (like a tiny shuttle) that I am going to eventually put in my car. There is no room inside for a power supply (it has an external one). This is going to be placed on the floor in the backseat of the car.
    Anyway, it seems like a lot of people here are using regular (modified sine wave) power inverters here. I don't know how much voltage regulation, etc. the stock power supply for my MIPI case offers, and I will also be plugging in a Lilliput 7" once I get one in the next 2 months.
    So my question is, why don't I see too many people using Pure Sine inverters rather than Modified Sine inverters? Wouldn't a Pure Since perform much better, and avoid many damaging spike via PWM (Pulse Width Modulation)?
    Is it just overkill? I can get a dual AC outlet 150 watt Pure Sine for around $80 and a 300 watt one for around $120 I think.
    Thoughts? Comments?
    Thanks,
    Brain21
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    I think the main reason people use modified sine is cost. Pure sine is way more expensive, and the advantages are negligible. I haven't seen anyone who's posted a problem with power spikes.
    Also, I don't know if they're more or less efficient than modified sine.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    Nov 2004
    Pure sine are less efficient that modified sine (modified square actually). I've checked the instructions for my Nikkai 300W modified sine (square) inverter, and it says to check with the equipment manufacturer whether it's ok to power it using modified sine. I guess if the manufacturer says it is, and the inverter then blows it up, you would be able to go back to the inverter manufacturer for comp??
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The cost of a pure sine inverter will cost about the same (maybe little more or less)as the Opus. So people either go with Opus (or other DC-DC route) or the cheaper modified sine wave inverter.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. FS : 3D Render Card - ART VPS - PURE P1800 PCI
    By ccsnet in forum Classified Archive
    Last Post: 03-09-2004, 09:36 AM
  2. Replies: 1
    Last Post: 03-04-2004, 07:02 AM
  3. Power Problems Please Look
    By kmfdmk in forum General Hardware Discussion
    Last Post: 02-15-2004, 09:39 PM
  4. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
  5. power inverters . . . .
    By pSyCo in forum General MP3Car Discussion
    Last Post: 08-04-2000, 06:00 PM
