Results 1 to 10 of 17
Thread: Car stable 12v for <$3 ?
    Nov 2004
    OK, I am not sure if this will work, but I just started looking at car PSU and thought this might be interesting ....
    How about connecting as follows :-
    Car (10-15v)---| 7809 |----------| 7812 |------ 12v regulated
    Car ground ------+ 18v |
    . ---+---- v |
    Car (10-15v)---| 7909 |--------------+--------- Ground
    Of course thow in a few capacitors to smooth it out, but will this work ?
    Quote Originally Posted by lostbrit
    . ---+---- v |
    Works in theory, you still obviously need a DC - DC PSU. Also are you willing to manually switch the PC on and off everytime you start and stop.
    Nov 2004
    Why would I still need a DC-DC converter ?
    The idea is that out of an unregulated 12-15v DC supply I make +9v and -9v. This gives me an 18v regulated supply for feeding the 7812 and getting a 12 v regulated output. Might be able to cope with a drop in the supply voltage (starting) by putting a couple of hefty capacitors on the front end. Otherwise I dont see why the pc woulnt just start up and stop as the ignition was turned on/off.
    The only drawback I see is that i think you would have to run a 7805 off the regulated 12v so that you can have a common grounf between them. Not a big deal just have to beef up the 7809/7909/7812 to cope with the extra load.
    Mar 2004
    Vancouver, BC, Canada
    You still need a PSU so that your motherboard has something to connect to.
    I believe an ATX PSU connector has about 14 connections...
    Zac
    Zac is offline
    Feb 2004
    VA
    +9v + -9v = 18v? (Seriously??? I have no clue here. :P)
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    ah, thats why we call voltage, Potential Difference.
    Nov 2004
    OK, I refined it ... using a 7805 trimmed you can generate a regulated +6v output. Then using a 7905 you can generate a regulated -6v output. Connect these to give a regulated potential difference of 12v. Use this to drive a second 7805 and you have a regulated 5v output that shared the same ground point. (See diagram).
    I am using a single board computer that only needs +12v and +5v so I should be ok. I just need to figure out how to handle the 'power good' part of the circuit. Any ideas out there ?
    For you ATX people who need 3.3v, a third regulator hanging fron the regulated +12v line should give you everthing you need.
    Nov 2004
    OOPS ! Wrong connection on the front end regulators, please see revised diagram.
    FLAC Chairboy's Avatar
    Jan 2004
    But... those regulators are 1 amp max. 12 watts ain't enough.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Nov 2004
    78xx and 79xx go up to about 3A. Which will be enough for my board. If you need more there is a power transistor tweak that will take a 78/79xx up to 10A.
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 01:39 AM
  2. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 08:34 AM
  3. 12v for LCD?
    By MikeHunt79 in forum Power Supplies
    Last Post: 03-29-2005, 01:47 AM
  4. god damn university car regulations
    By MikeHunt79 in forum Off Topic
    Last Post: 09-27-2001, 12:02 PM
