Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Inverter not booting pc after second try
  1. #21
    Sep 2003
    Do you really think that modifed sine wave inverter manufacturers who sell millions of units per year just get lucky when their customers buy the units. Considering that dc inverters have been around since the late 60s in the consumer market?
  2. #22
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Quote Originally Posted by IntellaWorks
    You got lucky.
    Me and a whole bunch of other ppl. I'm starting to think you may be completely wrong if that's your response to my thoughts.
  3. #23
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Quote Originally Posted by ChrisC
    What do you mean by stress? Do you mean that the capacitors dielectric has broken down? If so the inverter would purely not work at all or cause very spiked output all the time , load or no load. Then again this could depend on which capacuitors.
    The inverter can support 1000W peak spikes for upto 0.5 seconds which is why it is designed in this way. The power supply is 250W and the inverter is 300W and the pc probably only uses about 180-200W at max. So I dought its because the components in the inverter at being pushed. I have run the PC on a 140W inverter before with no issue apart from it heated up after a hour or so and shutdown! This issue did not manifest itself.
    Why are you so ademant that a true sine wave inverter will solve the problem, what is the problem it will it solve exactly?
    Ambulance's computer equipment operates on True Sinewave Inverters, I'm adament about a true sinewave (if thats the route you want to take) because I know for sure it puts out good enough power for your computers powersupply. Your current inverter is producing power that your computers powersupply doesnt like.
    Every computers power supply is different, even if they are the same model they will operate differently.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  4. #24
    Sep 2003
    Anybody have any other views on things I should try to get this working?
  5. #25
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    I've got a feeling it's something to do with the inverter. My inverter plugs right into the cigerette lighter, currently I have to manually unplug it after shutdown and plug it back in to boot the computer. This is temp of course, I'll be looking into Falconey's way of shutting down soon or this Ghetto Startup/Shutdown Control for Inverter
    Anyways, sometimes I have to plug in the inverter twice. The first time nothing happens (I can see the PSU and MB and can tell if the lights come on from the driver seat). I then have to unplug it, wait for about 20 secs and then plug it back in. This usually starts it back up.
  6. #26
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Quote Originally Posted by TimmyM
    FYI - this is because the cigarette lighter socket only provides a limited amount of wattage/amps. You need to wire it directly to the battery to get efficient operation.
  7. #27
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by hd54321
    Not sure if thats true in this case or not. When I plug it in the first time I can hear the inverter beep. And it doesn't do it every time, I'd say about every 4th or 5th time. It also usually survives crank. My setup is currently temporary and when it goes perm, it will be wired directly to the battery. Guess we'll find out then.
  1. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  2. Replies: 34
    Last Post: 08-20-2004, 06:37 PM
  3. Xenarc acting strange once installed
    By Sivion in forum LCD/Display
    Last Post: 08-02-2004, 09:30 AM
  4. Grounding the PC when using an inverter?
    By csvt in forum Power Supplies
    Last Post: 12-21-2003, 12:48 PM
  5. FS: Casio EM500 Pocket PC / 800mhz Desktop PC / Misc
    By gguy in forum Classified Archive
    Last Post: 10-07-2001, 08:00 PM
