Results 1 to 7 of 7
Thread: PSU and mini-ATX
    Oct 2004
    PSU and mini-ATX
    Hi,
    - Does the power supply "PW-70A 12V DC/DC (100 watts)" works in mini-ATX Motherboard ?
    - Does the ITPS works with a mini-ATX motherboard.
    - Can I connect at the same time the TFT and the PC on the same power supply ?
    PS: The mobo is a mini-atx PC-Chips with a Via C3 Samuel 2 CPU, and I have 1HDD, 1 stick of ram, 2 joystick USB and a GPS USB (and a Lilliput with touchsreen)
    Constant Bitrate naveedh's Avatar
    Oct 2004
    Wink
    Quote Originally Posted by Matusa
    Hi,
    Screw that idea, buy a opus. You will say expesive but in the long run it WILL WORK and be safe. That would work with a mini atx but by the looks of it it wont be enough power. Also use the
    Oct 2004
    I searched, and I asked to the shop where I'll buy.
    I found a 80W PSU with a nice voltage tolerance range (10.8-20V) but I don't know if that's enought for my config, I used all of the calculators, but my procesor didn't appear in anyone... How can I mesure that myself?
    How can I use the ITPS only as a shootdown controler?
    Thanks!
    Jun 2004
    I have the 80 watt PS that is also a regulator (pw-80) and ordered an ITPS. You can solder two pads together to stop it from being a regulator (it only does 5 amps, 60 watts), but unregulated, it seems to be good for 220 watts.
    I think the max power that CPU uses is 12 watts if it is the 1 gig one.
    I think that even with a full sized 3.5 hard drive, you MIGHT be able to do it. If it is the pw-80 PSU from Mini-box.com, they oddly enough have it rated at 60 watts of power now though, not 80 like it was when I bought it, so I don't know if they just over rated it before, or under rate it now.
    I have a Mini-ITX Via board with the 600mhz processor, a slimline DVD drive, 2.5 laptop drive, and various USB things, and I have no problems with power. Even running a full sized hard drive and dvd drive it worked, but I didn't use it too long to be sure it would be stable.
    Oct 2004
    Thanks for the answer, I'm looking @ european sites (I live in belgium) for a Opus of 150W, with that I normaly can run everything I have in mind..
    thanks
    Newbie Impalaman's Avatar
    Feb 2005
    Jonesboro, AR
    Mini Atx
    I have a Mini ATX board with a celeron processor. the boards power connector is a six pin connector (2 rows of 3) I want to buy an Opus 150w PSU. Does it have an adapter or is there a way to wire it up to work with what I have.
    If at first you don't succeed it probably wasn't meant to be
    Celeron 2Ghz
    256mb Ram
    60gb HD
    Dvd RW
    Opus 150w
    Lilliput 7" Touchscreen
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    impalaman, i see you posted your own thread for this question....it would help if you said what board you had......i bet the sellers of that boards sell power adapters
    PC Components:
    My work log
  1. WTB mini ITX CASE and DC -DC PSU
    By Darkstar757 in forum Classified Archive
    Last Post: 09-04-2006, 03:38 AM
  2. Morex 120W & ITPS for AMD micro ATX - good idea?
    By Arathranar in forum Power Supplies
    Last Post: 10-14-2004, 04:20 AM
  3. Aopen mini ATX PSU !
    By Avner in forum Power Supplies
    Last Post: 03-04-2004, 11:53 PM
  4. ATX PSU Hack with inverter (Old subject I know)
    By dekodan in forum Power Supplies
    Last Post: 08-01-2003, 09:15 AM
  5. micro / mini atx system w/ LCD and all the goodies
    By gizmomkr in forum Classified Archive
    Last Post: 05-09-2001, 04:08 PM
