Results 1 to 5 of 5
Thread: AC Wattage vs. DC Wattage
    Feb 2004
    Las Vegas, NV
    I just ordered a Kill-a-Volt to help me measure power usage around the house, and I thought I'd also use it to measure how much juice my soon-to-be-installed carputer will suck up. Is there any difference between AC wattage and DC wattage? I'll be using the Kill-A-Volt to measure my carputer plugged into my wall. Can I use that measurement to figure out big a DC-DC OPUS to get?
    Yes it will be close enough.
    Be sure to measure it when doing something as intensive as possible (download and run prime95 or something) to get your upper limit draw.
    Newbie Laetitia's Avatar
    May 2004
    You will need to estimate your AC power supply efficiency: that is the ratio between the AC power used ( read by the kill-a-watt ) and the DC power delivered ( used by the PC ), the difference is dissipated as heat.
    Common ATX power supplies tend to be in the 50-80% range ( depending on load and make )
    Feb 2004
    Las Vegas, NV
    Good to know, thanks! Does this means that the Opus will draw 20-50% less power than an AC ATX PS?
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    no because the opus is about 90% efficient depending on which model you choose
    Signature: [==||========] 20% complete
  1. Possible to turn a DC Toggle switch into AC???
    By Defiler in forum General Hardware Discussion
    Last Post: 07-05-2004, 09:29 PM
  2. AC or DC power supply w/ tablet pc?
    By gutterslide in forum Power Supplies
    Last Post: 04-07-2004, 04:12 AM
  3. 3 volt AC from dc?????
    By saletel in forum Power Supplies
    Last Post: 07-30-2002, 05:42 PM
  4. dc or ac power supply
    By qball008 in forum Power Supplies
    Last Post: 05-16-2002, 11:22 PM
  5. Need help finding an AC to DC power adaptor
    By Squeezer in forum General Hardware Discussion
    Last Post: 12-29-2000, 01:27 PM
