Page 1 of 17 1234567891011 ... LastLast
Results 1 to 10 of 161
Thread: Revised New 16A 12V Regulator Circuit Double Checking
    Nov 2004
    Ok, I first want to thank everybody who helped answer my questions on my last post Building a 12 V 15 amp Regulator got some ?. Since then I have made some changes and wanted to double check that everything will work.
    Ok so I have same basic problem as before. I bought an unregulated power supply instead of an opus and am now trying to get it to work by creating my own 12 volt regulator since I can not seem to find any decently priced product out there. If you know of something please let me know.
    So I have finally found a PCB board, I believe http://www.digikey.com/scripts/DkSea...?KeywordSearch. It is basically a veroboard that is mentioned in the last post as far as I can tell. This should work very well for what I'm trying to do with it being such a simple circuit.
    Alright so last time I used two 7.5A regulators. This time I have decided to go with 8 2A regulators http://www.digikey.com/scripts/DkSea...?KeywordSearch with these heatsinks on them http://www.digikey.com/scripts/DkSea...?KeywordSearch. I did this for a number of reasons. 1st of all it was cheaper, saved me around a buck with an extra amp of output. Next, this one is a fixed 12 volt output so no need for resistors. While the last one had a max drop out of .7 volts. This one is only .5 volts at 2A. The last two reasons I changed was to spread out the heat over a larger area and to also not have as many amps running through each channel. Before I would of had 15 amps running through one wire. I now will only have 4 amps running through each wire.
    The next thing I have done is to put in a number of capacitors http://www.digikey.com/scripts/DkSea...?KeywordSearch. Since they are so much cheaper for 10. I will be putting 4 of them on the input and of them on the output. I really don't know too much about capacitors so if these aren't the right type please let me know thanks.
    Other than, it's pretty all the same. Since I never received any response on why I can't parallel the regulated power coming from the ITPS with the output my circuit I have decided to do away with it and will only be using the ITPS to send an on signal to the regulators as well of course sending the on and off sends to the systems motherboard. Thanks again for all your help and let me know if there is anything I'm missing or needs correction. Thank you.
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    whats wrong with the carnetix?
    Signature: [==||========] 20% complete
    Nov 2004
    Quote Originally Posted by Nic
    I've never tried that, however that is beside the fact considering I have already spent $90 and don't feel like spending anymore than I have to for another power supply when all I need is for more filtered source power
    May 2004
    Hi, which chip are you using? I plan to build a 12v 1A power supply for my dvd player.
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Quote Originally Posted by triwav
    All the links seem to point to search page only. Can you please post links to direct items such as PCB and/or schematics and parts list?
    Nov 2004
    Quote Originally Posted by mpattonm
    Oops sorry about that. That's one of the problems with their website. Type these part #'s in their seach engine:
    regulators-PQ12RD21
    PCB-V2018-ND
    Capacitors-P5156-ND
    Heatsinks-HS113-ND
    What's wrong with 3 of these 5A 12V regulators at $1.92 each?
    http://www.digikey.com/scripts/DkSea...293461&Site=US
    Variable Bitrate HummDinger's Avatar
    Aug 2004
    Milwaukee, WI
    The carnextix is no where near 16 amps. It's only 60 watts, wich is about 5 amps according to there website. 60 watts is kind of hard to get by with if you have a power hungry system.
    You can still have something if you have nothing
    May 2003
    Czech rep.
    can some1 point me at circuit diagram?
    Nov 2004
    Quote Originally Posted by Arathranar
    If you looked at those, they have a LDO voltage of 1.5 VOLTS!!! that is WAY too much of a loss. Yes they're a lot cheaper in terms of amps per dollar but they won't work for this application.
