Results 1 to 10 of 10
Thread: ITPS reprogramming ?
    Nov 2004
    Question ITPS reprogramming ?
    Hello,
    i will reprogrammning my iTPS device, then 45 seconds is for me to fast.
    is my new programm right or id there a ather way to programming the turn of secuence make to 13 for switch shutdown and 15min for hard power off ?
    my programm
    ONDELAY equ .5 ;power on delay 1 seconds
    ONDELAY2 equ .5 ;wait 1 second until push button
    BUTTON equ .1 ;push button for 400 ms
    OFFDELAY equ .3900 ;shut down 13 minuten after ignition off
    HARDOFF equ .4500 ;hard off after 15 minuten
    Old programm
    ONDELAY equ .20 ;power on delay 4 seconds
    OFFDELAY equ .25 ;shut down 5 s after ignition off
    HARDOFF equ .225 ;hard off after 45 seconds
    Naruto
    Raw Wave
    Jun 2003
    Quote Originally Posted by naruto
    I dont know what version of firmware you have but what you propose wont work. The program wont take in more than 255 for the delay because its only working within a single byte.
    You will need to add code such that it will loop a much longer delay. Or make a delay that take in 2 bytes values up to 65535 delay value.
    Im sure theres a modified ITPS firmware that do this, ask around
    Nov 2004
    i search the forum before and the only was i found is from brooksware2000 that he will post a programm this was at june
    Or a Power ON/OFF Programm from you
    My problem is i have no programming knowlage to programming the ITPS complete new with a loop.
    When there is a FW that has a longer shutdown sequence please sent me the HEX file.
    THX
    Naruto
    P.S. my Firmware what i use was the FW from itps3.zip
    Raw Wave
    Jun 2003
    I cant remember the name of the user who got hold of the modified firmware from the ITPS company.
    The firmware is supposed to have a longer time delay.
    Start a thread or something...or else mail the ITPS guy for the longer delay version of their firmware. Im 99% it does exist
    Nov 2004
    I wrote to sipport@mini-box.com i found no other adress
    Cu
    Nov 2004
    Hi,
    i progged with RedZac from another forum a modified fw over a variable there is a shutdown time from 1min to ..... min
    THX
    Naruto
    Jun 2004
    Sydney, Australia
    What forum was that? Any more details?
    Nov 2004
    Hi,
    this forum http://www.car-pc.info/phpBB2/viewforum.php?f=5
    when you need the programm, please send me a pn with your email and i sent you this programm,
    i dont know of right it alowed to put the fw on the forum ?
    The FW has a new variable for min shut down easy way for all times 1 min to xx
    cu
    Naruto
    Jun 2004
    Sydney, Australia
    Thanks, unfortunately my German is a little rusty
    I also dont know about the legality of posting the firmware; but others have posted firmwares before... Anyway, i sent you a PM...
    Nov 2004
    OK here is the source
    ; Ituner power sequencer
    ; Modifiziert von Michael Forter und Naruto
    ; pd 030611 initial code
    LIST p=12F629 ;Target processor
    #include "P12F629.INC" ;Header file for target processor
    ; GP0 = VSW12 input 1 = ignition turned on
    ; GP1 = ON output 1 = turn power on
    ; GP2 = MBON# o.d. 0 = power button pressed
    ; GP3 = n.c. input
    ; GP4 = MBON2# o.d. 0 = power button pressed (parallel out,
    ; makes connector flip-tolerant)
    ; GP5 = n.c. output 0 = terminate unused pin
    ; Schutdown Zeit einstellen die länge kannst du im wait3 oder im wait2 ändern
    ; wait1 ist ca. 250ms
    ; wait2 multipliziert mit 255. also 255 mal 250ms
    ; und wait3 das ganze nochmals mal timeoff
    ; Equates
    PWR_OFF equ 0x00 ;power off state
    PWR_ON equ 0x02 ;power on state
    SW_ON equ 0x09 ;direction for switch on
    SW_OFF equ 0x1d ;direction for switch off
    ONDELAY2 equ .2 ;wait 800ms second until push button
    OFFDELAY equ .5 ;shut down 5 s after ignition off (nicht mehr so wichtig wg Timer)
    timeoff equ D'10' ;ca. 10min Pause 1= 1,02 min HIER ÄNDERN FÜR ABSCHALTDAUER !!!
    ; Register variables
    cntr equ 0x20 ;state counter
    cntr2 equ 0x21
    waitl equ 0x22 ;delay counter low
    waitm equ 0x23 ;delay counter mid
    waith equ 0x24 ;delay counter high
    loops Equ 0x25 ; Zähler für Warteschleife
    loops1 Equ 0x26 ; Zähler für Warteschleife
    loops2 Equ 0x27 ; Zähler für Warteschleife
    loops3 Equ 0x28 ; Zähler für Warteschleife
    ; reset entry
    org 0
    goto reset
    ; interrupt entry
    org 4
    retfie
    reset
    banksel OSCCAL ;get oscillator calibration
    call 0x3ff
    movwf OSCCAL & 0x7f
    movlw b'100000' ;enable weak pull-up on
    movwf WPU & 0x7f ;GP5 (doesn't seem to work...)
    movlw b'00001101' ;set option register
    ;enable weak pull-ups
    ;timer0 internal clock, positive edge
    ;prescaler -> WDT, 1:32 -> ~0.5s
    movwf OPTION_REG & 0x7f
    reset2
    banksel TRISIO
    movlw SW_ON ;set pin directions
    movwf TRISIO & 0x7f
    banksel GPIO
    movlw PWR_OFF ;set initial state
    movwf GPIO
    movlw 7
    movwf CMCON ;disable comparator
    clrwdt ;clear watchdog
    ; initial state - wait until ignition is on for ONDELAY
    initial
    banksel GPIO
    movlw ONDELAY ;initial power on
    movwf cntr
    initwait call delay200 ;wait
    btfss GPIO,0 ;ignition on ?
    goto initial ;no: clear counter
    decfsz cntr,f ;initial time-out
    goto initwait
    ; turn power on, wait ONDELAY2
    turnon movlw PWR_ON
    movwf GPIO
    movlw ONDELAY2 ;wait for ONDELAY2
    movwf cntr
    turnon1 call delay200 ;wait
    decfsz cntr,f
    goto turnon1
    goto reset2 ;no: turn off again
    ; push the system board power button
    banksel TRISIO
    movlw SW_ON ;push the button
    movwf TRISIO & 0x7f
    banksel GPIO
    movlw BUTTON ;wait for BUTTON
    movwf cntr
    button1 call delay200 ;wait
    decfsz cntr,f
    goto button1
    banksel TRISIO
    movlw SW_OFF ;release the button
    movwf TRISIO & 0x7f
    banksel GPIO
    ; power on state - shut down if ignition off for OFFDELAY
    onstate movlw OFFDELAY
    movwf cntr
    onstate1 call delay200
    btfsc GPIO,0 ;ignition on ?
    goto onstate ;yes: reset timer
    decfsz cntr,f
    goto onstate1
    ; Warteschleife für Power OFF
    Wait3
    movlw timeoff ; zeit wie Variabel
    movwf loops3
    Wait2
    movlw D'255' ; 63,75s Pause
    movwf loops2
    Wait1
    movlw D'125' ; 250 ms Pause
    movwf loops1
    Wai
    movlw .220 ; Zeitkonstante für 1ms
    movwf loops
    Wai2 nop
    nop
    nop
    nop
    nop
    clrwdt ;Watchdog reseten
    decfsz loops, F ; 1 ms vorbei?
    goto Wai2 ; nein, noch nicht
    decfsz loops1, F ; 250 ms vorbei?
    goto Wai ; nein, noch nicht
    decfsz loops2, F ; 63,75s vorbei?
    goto Wait1 ; nein, noch nicht
    decfsz loops3, F ; 14.875min vorbei?
    goto Wait2 ; nein, noch nicht
    onstate3 movlw OFFDELAY
    movwf cntr
    onstate2 call delay200
    decfsz cntr,f
    goto onstate2
    ; shut down - push the system board power button
    banksel TRISIO
    movwf TRISIO & 0x7f
    banksel GPIO
    movwf cntr
    button2 call delay200 ;wait
    decfsz cntr,f
    goto button2
    banksel TRISIO
    movwf TRISIO & 0x7f
    banksel GPIO
    ; turn-off state - turn off power after HARDOFF
    ; go back to restart after ONDELAY
    movlw HARDOFF
    movwf cntr
    movlw ONDELAY
    movwf cntr2
    shut1 call delay200
    goto shut2 ;:no
    decfsz cntr2,f
    goto turnon ;go turn-on if ignition on for ONDELAY
    goto shut3
    shut2 movlw ONDELAY ;ignition off - restart on timer
    movwf cntr2
    shut3 decfsz cntr,f
    goto shut1 ;keep waiting
    goto reset2 ;do hard power off
    ; retlw 0 ; das Warten hat ein Ende
    ; 200 ms delay routine
    delay200 clrwdt ;tickle the watchdog
    movlw .1 ;note count is +1 (decfsz !)
    movwf waith
    movlw .0
    movwf waitm
    clrf waitl
    del1 decfsz waitl,f ;delay loop - 3 us per iteration
    goto del1
    decfsz waitm,f
    goto del1
    clrwdt
    decfsz waith,f
    goto del1
    retlw 0
    ; oscillator calibration - comment out for production !!!
    ; org 0x3ff
    ; retlw 0x94
    ; define configuration bits
    __config _MCLRE_OFF & _CP_OFF & _WDT_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
    ; external reset off
    ; code protection off (not read protected)
    ; note: if code protection is switched from on to off, OSCCAL
    ; value is erased too !!!
    ; watchdog timer enabled
    ; data memory protection off (not used)
    ; internal RC oscillator
    ; brown-out detect enable
    ; power-up timer enable
    END
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. ITPS Startup Shutdown Controller Not Working
    By EBJUSTIN in forum Power Supplies
    Last Post: 09-11-2004, 09:04 PM
  3. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 11:48 PM
  4. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
  5. ITPS Power Sequence review
    By saito in forum The Review Palace
    Last Post: 12-18-2003, 10:26 AM
