Results 1 to 7 of 7
Thread: Morex 60W car kit
    trdcpu's Avatar
    Feb 2004
    Colorado
    Morex 60W car kit
    my Epia m10k works fine with the 60W morex psu that came with it, but when i
    removed it and replaced it with the 60W morex psu car kit, it will not boot up.
    yes, ive used the button. and please do not reply with any useless
    information like " you need to buy an opus" or "use the search tool" so i repeat,
    only relevant helpfull information is required. thanks for the help.
    trdcpu's Avatar
    Feb 2004
    Colorado
    well, the 60W car psu just makes a very high pitched hum, when i press power, it doesnt light up the mobo.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    what are you using for power to test it out?....if your using a power supply, it probably isnt enough. If you are in fact using a car battery...I am then at a loss.
    2005 Ford Focus ST
    trdcpu's Avatar
    Feb 2004
    Colorado
    ill go try the car battery. the brochure says "the Morex Car Power Kit not only lets you power up systems in your car, but also can be used in house by using an external 12V AC adaptor"
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    The PSU is a dud
    I had a 80w MOREX PSU just made a loud wine and thats it i got a replacement and i foundout they sent me the home version instead of the car version.
    Does the morex look exactly like the orignal morex that came with it installed?
    that would be the problem i bet i had the same thing.
    Ask for a new PSU it wont cost u anything besides paying for shipping back to them
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    trdcpu's Avatar
    Feb 2004
    Colorado
    it almost looks exactly like the other one, but the car kit has a slot to run some wiring to the voltage regulator that comes with it. has anyone had problems like this with their morex psu?
    trdcpu's Avatar
    Feb 2004
    Colorado
    problem solved. the kit comes with two different harnesses to run power to the regulator, it appeared as if the kit only came with one, the other was camoflaged inside an atx power cable. that set of wires worked.
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 07:34 AM
  2. Just for laught: Computer and Car
    By MatrixPC in forum Off Topic
    Last Post: 01-05-2005, 09:25 PM
  3. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 04:08 AM
  4. Sirius tuner AND home or car kit $50.00 total
    By pc832 in forum Car Audio
    Last Post: 10-12-2004, 06:49 PM
  5. FS: Morex Car Power Regulator Kit (Brand New)
    By migel628 in forum Classified Archive
    Last Post: 04-06-2004, 11:26 PM
