Results 1 to 6 of 6
Thread: NewB here; need some clarification
    Newbie David_K's Avatar
    Nov 2004
    Austin
    Built-in 120W DC power board and external AC Adapter
    What does this mean? can I hook it up to my car battery?
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Built in DC-DC means you plug in DC (direct current, from the car) power to the computer.
    AC adapter typically means it turns AC (or power from your house) to DC power
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    Quote Originally Posted by David_K
    In general you have two options with many variances
    DC to DC where you use 12 volts DC PSU to suppy the voltages needed to run your computer: Search Opus as a start point
    Inverter where you use 12 volts dc converted to mains AC and then use your normal PSU: Search Inverter
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
    Nov 2004
    Austin
    OK cool. So i can splic the DC-DC into the car; like going through the cigarette lighter fuse in the fuse box.
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    Wellcome to the boards, and wellcome in the camp of texans!!!
    Oct 2004
    UK Midlands
    Not so simple you will have to use a quality connection as it will draw a lot of power, ideally back to the battery with fuse The earth must be solid to work properly. The dc dc psu is a special unit for the job search on it look for OPUS in this forum as a start point. I do not know the ins and outs of this yet as I am still in the planning stage but dont fit anything till you know exactly what your doing. If in doubt ask, but search first or you will get some heat if a solution is posted for all to see.
  1. Wireless newb...needs help
    By Herb_Davis_Y2K in forum Wireless Communications
    Last Post: 10-20-2004, 08:46 PM
  2. Newb carputer set up, advice & help needed.
    By Rykielz in forum Newbie
    Last Post: 07-26-2004, 04:26 PM
  3. Newb question about standard psu's
    By newbiemcnewb in forum Power Supplies
    Last Post: 06-06-2004, 11:05 AM
  4. Replies: 5
    Last Post: 09-28-2003, 05:57 AM
  5. Help a newb :)
    By Panthr710 in forum General Hardware Discussion
    Last Post: 07-15-2002, 09:19 AM
