If anyone can help me out please do so.
I got my carcomputer all up and running and everything worked great for about a month and a half, a couple days ago it all just stopped working, so I checked back where the computer is located and noticed that no lights were blinking on the opus power supply, I know both the power and acc line are getting plenty of power, checked it with a volt meter, and the ground is good, another reason I know this is because I have a distribution block and the opus and amp are hooked up to that, the amp turns on with the car but I get nothing with the opus.
Another question if all the power is being correctly fed into the opus should the green light blink even if its not hooked up to the computer? (for testing purposes)
thanks,
any help would be greatly appreciated
I'm pretty sure you don't, I live in billings if thats of any help
a budy of mine had the same problem yesterday
thats why i asked
anyone?
I had that problem once. I unplugged the power cable from the Opus (the molex style connector), then plugged it back in to 'reset' the logic. Light started blinking again, it works now.
Chrysler 300 - Fabricating
http://hallert.net/
I had the same problem a few nights ago. After pulling everything out of the case, and testing everything, I couldn't find any problems. I let it sit for a night then pluged everything back in and it worked with no problem. Hope this helps.
dang, I've tried that a couple times, still doesn't work
Jermkesler, did you try unplugging the Opus from power?
http://hallert.net/
