Results 1 to 8 of 8
Thread: Running Opus 150 without internal fan?
    Newbie biglips31's Avatar
    Redwood City
    Got my system up and running this weekend and boy is that fan loud. My install is inside the center consule area with plenty of room. I belive my system is rather easy on my supply.
    MK1200, 512ram, 3.5 Hard, Slim DVD, Audigy NX usb, GPS USB, 4 usb port, Lilliput on 12 rail, Amp turn on 12 rail.
    I would like to uplug fan on supply. Any opinions on this.
    Carputer in design stage...
    Currently working on Lilliput In Dash Install...
    MII 12000 + 512Mb Ram + Panasonic Slim DVD, CDRW + Lilliput 7" + Opus 150W + 3.5 120gb Drive... most parts on order!!
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    If you have good airflow already and you've taken it out of its case then you can do without it. The heat buildup if you unplug the fan & leave it in its case will probably reduce the efficiency of the supply. It could overheat.
    Redwood City
    The power supply is still in its case. I was thinking of removing
    the fan and its cover and leave it open. Its protected by center
    consule.
    If it does run hot, will the supply just shut down and give a trouble
    code? If so, I could always try it if I dont run this risk of damaging
    anything.
    pip
    pip is offline
    Mar 2004
    Parker, CO
    I guess that'd be a question for Opus. I suspect that the hotter it gets the less eficient it'll be. I don't know if there is a thermal cut-out on board. I'd recommend using a big PC-case style fan (quieter) to move air from outside through the compartment the PC & power supply is installed. A bigger, slower fan will be a lot quieter and still move as much (if not more) air.
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    a 120 mm panaflo on 7 volts would be a near silent solution, an 80mm 'flo if space is a problem (but the CFM is not great at 7v on 80s)
    Constant Bitrate Troy McClure's Avatar
    This post is just food for thought..........
    I have the Opus Shuttle 150 and it does NOT have a fan. Out of curiousity, I e-mailed Opus about this because I know their other 150 PS has a fan. They told me that the aluminum housing used on the Shuttle model to hold the assembly together was good enough for heat dissipation as the aluminum acts like a big heat sink.
    Maybe you could make something up to mimic the shuttle and dissipate heat?
    Troy
    Done!
    If you're into fishing, checkout my website! http://www.pennsylvaniaanglers.com
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Try the fan with 5 or 7 volts instead of 12. Or replace the fan with one that is not as noisy.
    I would not recommend running without a fan.
    TruckinMP3
    Read the FAQ!
    Nov 2004
    UK
    Or use a a fan which changes it's speed dependant on temperature.
    I bought some 80mm ones off E-bay for my amps, they were less than £5.
    That way you needn't worry and they'll only be as noisey as they need to be.
  1. Opus 150 and System issues
    By septicdeath in forum Power Supplies
    Last Post: 09-17-2004, 12:38 AM
  2. Will it work? Your best guess. Opus 150
    By the_dude in forum Power Supplies
    Last Post: 05-05-2004, 09:09 PM
  3. opus 150
    By vp911 in forum Classified Archive
    Last Post: 04-30-2004, 10:42 AM
  4. Opus 150
    By hawaiian00exp in forum Power Supplies
    Last Post: 04-21-2004, 10:37 AM
  5. Replies: 9
    Last Post: 11-01-2002, 12:21 PM
