Results 1 to 7 of 7
Thread: Problems with Xantrex inverter...
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Hi all!
    I'm having 2 problems with my Xantrex 400watt inverter.
    Here goes... I hope someone can help!
    1) My inverter doesnt surviv Crank... Even if nothing is plugged in it, when I crank the vehicle, th inverter alarm sounds for 1-2 seconds while the car starts. If the computer is plugged in, it looses power and is forced a hard bootdown... I have read others here saying the xantrex survives crank for them?! WTF???
    2) OK, I have my Xantrex inverter wired directly to the battery, and grounded to the body of the vehicle. I have my Xenarc plugged in the cigarette lighter. When the computer is turned on (powered by the inverter), there is some "interference" on the screen. Basically lines that scan from up to down on the screen, like when filming a computer crt monitor... I was told that the inverter could be causing interference on the 12v line of the Car, that was causing the itnerference on the screen. To test this out, I plugged the inverter with aligator clips, on ANOTHER car, so I had 2 separate 12v systems... There was NO INTERFERENCE. Then I powered the screen with the 110v PS it came with, fromt he inverter, together with the computer, again NO INTERFERENCE. Basically, I got to the conclusion that the inverter is causing noise on the system somehow... How can I filter it out? I dont want to have to use the xenarc 110v powersupply if the screen is 12v! (The above happens with the engine on OR off, it is not engine-induced noise, and henceforth is not to do with alternator or anything...)
    Thanks for all help! Although I think at this point the crank part is getting me more upset! (Oh, I had my battery checked and they said the battery was fine... i should also say that I forgot the computer on, and the inverter drained the battery! It sounded an alarm but DID NOT cut the current! It is a Range Rover 4.6 V8 engine, with 100Amp battery.)
    Feb 2004
    Las Vegas, NV
    With an inverter, results will vary when you try to crank it. Sometimes an inverter will survive a crank, sometimes it won't. I've got the same inverter and it doesn't survive a crank. It does once in awhile, but not often.
    São Paulo, Brazil
    Mine never has.... it is straight to the battery, ALWAYS ON, and never survives a crank... I'd understand it wouldnt be able to survive 2 cranks in a small period of time, but this is just ridiculous....
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I went through 2 inverters before I found one that would survive crank and run without the engine running without sounding a low battery alarm. Mine is a APC
    肚子笑痛了
    S60 Install
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    I have Xantrex as well but it never survives a crank
    toooooooooooooooooo bAD
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    Maximum Bitrate dodgetimes2's Avatar
    MI
    It's probably not the most economical solution but has anyone with an inverter that does not survive crank tried a higher amperage battery? Maybe an Optima? Haven't got mine installed yet, so I have my fingers crossed if mine will survive crank or not.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    Isn't this why you use a tank circuit, or am I way off?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. Having problems with my inverter... any ideas?
    By chris in forum General Hardware Discussion
    Last Post: 08-08-2006, 11:15 PM
  2. relay, inverter, fuse problems
    By cheesyhoward in forum Power Supplies
    Last Post: 06-02-2005, 10:04 AM
  3. relay, inverter, fuse problems
    By cheesyhoward in forum General Hardware Discussion
    Last Post: 06-22-2004, 04:05 PM
  4. Problems with inverter powering up from SDC
    By audrenaline in forum Power Supplies
    Last Post: 03-11-2004, 07:36 PM
  5. 300 watt power inverter problems
    By DaPyro in forum General Hardware Discussion
    Last Post: 03-10-2000, 03:56 PM
