Results 1 to 10 of 19
Thread: How do I start my amps from the pc at boot???
    Low Bitrate IonDokk's Avatar
    Michigan
    I have to find a way possibly through the serial port or usb so that I can trigger a relay to start my amps and preamps @ full boot. Because of my ground configuration, I use a open ground loop which gives me engine noise only when the pc is not booted on full boot it will go away. Must be that the pc is on a fixed ground loop.
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
    Jul 2004
    Business Class
    Well you could program something using components from phidgets.com OR you could hook up the 5V line from your power supply to a relay to switch the amps on. This way, they will turn on when the PC turns on.
    AdamR
    Jun 2003
    Memphis - TN
    Im sure you could just use any +12V wire from a power connector to your remote wire, that way when your power supply is on, it turns on your amps.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    ....but he wants it to turn on after it has booted, not during
    2005 Ford Focus ST
    Jul 2004
    Business Class
    If you want it after then I would say to program something that loads on boot and uses a phidget USB relay
    Jun 2004
    I'm using a DTR control program from this forum.. ( for DTR)
    I've wired my serial port, to my amps remote.. This way, the amp turns on when windows is done booting, and shuts down the amp when the machine shuts down..
    Michigan
    ok that will work I tried a relay with a 5v trigger which will work so now I need to figure out what wire on the power supply triggers power at full boot?
    Newbie John M's Avatar
    Nov 2004
    Milledgeville, GA
    None. However, you can buy a variable turnon delay from any car stereo store or online that will take the incoming signal (I'd use a 12v wire from your PS, not 5v) and wait however long you set it for (from 2 seconds to 30+) and then it turns the amps on. You can build it yourself if you'd rather but it's about a $20USD solution if you buy it as a unit.
    2005 Subaru Legacy GT
    Status: 40% - starting install
    • AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
    • JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
    Jun 2004
    Central California
    IonDokk, one alternative is to use a time delay relay switch. That's what I use in my car.
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
  1. PC audio too low
    By Alphared in forum General Hardware Discussion
    Last Post: 10-04-2008, 05:20 PM
  2. A Bodgy Car PC.
    By Bodgy in forum Show off your project
    Last Post: 02-05-2007, 11:58 PM
  3. Auto boot without Auto start
    By phatbenny in forum Power Supplies
    Last Post: 09-22-2004, 06:19 PM
  4. Pc wont boot with new pw-70a, Any ideas?
    By chriswhittleuk in forum Power Supplies
    Last Post: 06-22-2004, 07:33 PM
  5. evaluate this in-dash tablet PC plan
    By dimas in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 11-15-2003, 07:50 PM
